Old 03-20-2016, 10:08 AM   #1
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
A little bit of refrigerator info....
Everyday can be a learning experience, and a few weeks ago I learned a bit about RV refrigerators.....
We had planned a week long trip to Mexico (Puerto Penasco, AKA.. Rocky Point)
so Sat. morning we got the Airstream all "road ready" and proceeded through the checklist before hitting the road. Hooked and with a green light to go, the last thing I did was disconnect the shore power and store the cord. On my way back around the trailer I came across the scent of ammonia. Not knowing what I know now, I attributed it to an earlier problem we had with the dump valves (since replaced) and figured the leaking must have been much worse than I thought and that the ground was a bit "tainted" None the wiser, off to Mexico we went. Upon arrival, not only was the refrigerator not cooling, it had no power at all! Spent some time doing a bit of troubleshooting and after an hour the call of vacation won the battle. Off to the store we went and lived out of a couple coolers for the week.
After our return to the States ( and subsequent internet service) I set forth on Google to become a "semi-professional" RV refrigerator repairman. (yet another badge to pin to my chest!) Low and behold! My quest was put to an immediate halt upon learning that...... when one in an RV smells the fragrant aroma of Ammonia, two things are going to happen. You are going to get out your wallet and your going to call a specialist.
So, I'll try to sum things up here in a relatively easy to understand process....
If your RV refrigerator is a 2 way unit (meaning it runs on 120V shore power OR on propane when your "unplugged") it uses Ammonia as a refrigerant in the cooling process. (something I never new existed and really is a fairly interesting system)
So, if you ever smell Ammonia in or around your refrigerator, turn it off immediately and start a search for an RV refrigeration repairman. If you don't and continue to run the refrigerator(maybe you either just don't notice the leak or aren't home when it happens), eventually all the ammonia will leak out of the cooling system and then a 12 volt hi temp overload breaker WILL overheat and shut off ALL power to your refrigerator. This will make you think that now the problem is even worse than you originally thought.
At first I told myself " The damn fridge is 15 years old, we'll just buy a new one". Well, a quick search of replacement units quickly made me reconsider ( $2200) I found an RV refrigeration specialist here in Tucson, AZ. whom I'd highly recommend (Trailer Refrigeration)http://rvrefrig.com/
They rebuild the cooling decks of RV refrigerators, which, once the refrigerator is removed from your rig and placed on a patio or driveway, is relatively east to remove and take in for service (believe it or not!)
When I asked him about the cause of the leak in my unit he told me it was just dumb luck that it decided to spring a leak moments before our trip. Most leaks happen to folks while they are traveling down the road. ( vibration and movement eventually cause a break in the refrigerant line) Our leak was found in the "boiler" and not necessarily caused by anything other than regular use. It still cost about $500 for the repair, however I removed the fridge and did all the "grunt" work myself. Something I believe he would do, for the right amount of $$. It was a great learning experience for me anyways
I figured I'd post this here in the Full Timers section because we tent to put our Airstream's to the real test. Our appliances get used "Full Time", not just on the occasional trip or holiday weekends, so naturally we may experience more issues. I wanted to share my story and experience because I honestly didn't know anything about the fridge, I never HAD to. It worked and thats all I knew. But, now I know.... If your fridge smells like Ammonia, turn it off and find a repairman.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 03-20-2016, 10:18 AM   #2
2016 30' Classic
Lorton , Virginia
As someone going full time, thanks for the info!
Zybane is offline   Reply With Quote
Old 03-20-2016, 04:25 PM   #3
Sioux Falls , South Dakota
You may have not only saved some money by not buying a new refrigerator, you may have saved even more money by not having to buy a new coach and contents. While they certainly all don't catch fire, far too many newer RV refrigerators have caught fire to suit me. Before we ever saw our Foretravel we had decided that when the RV refrigerator died it would be replaced by a residential unit.
Both Dometic and Norcold have had repeated problems in the past few years. They may have finally gotten it figured out, but I'm going to let others be the guinea pigs. In fairness, most of the fires seem to have been in refrigerators located in slides, so that isn't an issue for Airstreams.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 03-20-2016, 05:11 PM   #4
1999 28' Excella
New Orleans , Louisiana
I wrote 4/11/2014 Frig Ammonia Smell..airforums pretty much saved our lives by saying it is toast..turn it off.
badkat is offline   Reply With Quote
Old 03-21-2016, 11:33 AM   #5
Thanks for sharing. I had a similar problem with an ammonia leak right after we had filled the freezer with seafood to take up north. I tried to keep the seafood frozen with dry ice but by the time we got home all that was safe to eat was the shrimp. Should have cooked it all or salted the fish and lobster (ugh) to try preserving everything. Oh well, such is life.
rtaylor537 is offline   Reply With Quote
Old 03-21-2016, 01:06 PM   #6
1996 25' Excella
Tillsonburg , Ontario
Thanks for the info
I had the Refrigerator rebuilt a few years back and it cost $800 CAN to R&R and put in a new condensing system. I've often wondered what the labor cost for R&R would be!
JCW
JCWDCW is offline   Reply With Quote
Old 03-21-2016, 01:34 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Here is a completely different take - marine refrigerators - and a good argument against propane/ammonia refrigerators. Read LEWSTER's post especially.
There are places where you can buy a new cooling unit for your existing refrigerator rather than having someone custom repair yours. I wish I'd read this thread before I finished remodeling the Avion.
Paula
Old 08-13-2018, 02:34 PM   #8
chandler
2006 19' International CCD
pelham , GA
Dealer says that I have a small ammonia leak in 2016 Dometic refrig, and that it will go bad and should replace with new refrigerator? Any opinions? What I read on forums seems to agree.
chandler is offline   Reply With Quote
Old 08-25-2018, 09:44 AM   #9
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
2016 or 2006? I would push towards some type of warranty fix if it's a 2016 refrigerator, if it's a 2006 model that's a different story.....
Either way, if it has a leak you definitely need to get it repaired. Depending on your financial situation.......Replacement of the cooling system in the old fridge is pretty reliable and usually comes with a warranty on the new unit & will be MUCH cheaper than a new replacement unit (which will also come with a warranty)
Hensley Arrow
Old 03-25-2019, 03:23 PM   #10
KLK
1966 30' Sovereign
Wimberley , Texas
I have a mostly remodeled 1966 30’ Soveriegn Airstream and when I purchased it 3 years ago, it had a new refrigerator. It says “Nostalgia Electrics.” I left the Airstream unoccupied for a few months and when I came back, the refrigerator wouldn’t work. The power is good. I can’t find “Nostalgia Electrics” on the net, so I researched refrigerators. I believe it is a capacitor. I don’t have any experience repairing appliances. I’ve taken a photo of the place I think the capacitor is.
Has this happened to anyone else?
Would it be worth my while to go to the hardware store with my photo and see if they can find a replacement?
Any advice appreciated.
KLK is offline   Reply With Quote
Old 03-25-2019, 03:46 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sounds like a previous owner replaced the RV refrigerator with an electric dorm size refrigerator. The dorm size are a fraction of the cost, but do not give you the options that a propane/electric unit does. For the most part, the electric dorm size units are not built to travel down the road and be subject to the bouncing.
Richard
Little Bit of Rust Everywhere? arlanan Wheels, Hubs & Bearings 2 10-15-2013 01:22 PM
A little info please before buying a Classic... Corrales Kid Classic Motorhomes 6 03-18-2012 06:55 PM
little bit furthur :: 1978 Airstream Excella 500 wharfrat8995 Airstream Registry Discussions 0 10-16-2011 07:32 PM
Misc. questions about a little bit of everything I don't understand... carmanahwoo 1970-79 Tradewind 4 10-09-2011 01:10 PM
