Old 06-10-2013, 06:00 AM   #1
2011 25' FB International
Denville , New Jersey
75' to sewer connection
Hey all,
I'm renting a place for about 6 months w potential for full hookups. The only issue is that the sewer clean out is about 75' away from the trailer itself. The good thing is that is down grade as the pitch is good for the flow when I empty the tanks. I can't really disturb the landscape so I'm trying to stay away from running a pipe up to the airstream.
I need to find some type of "fire hose" style hose where I can roll up like such and store when not needed. Then, when I need I empty the tanks, I would just connect my hose, roll it out to the drain and empty.
Anyone have any suggestions on what I would use, where to find, and what size fittings, etc i need?
NJ2Cali is offline   Reply With Quote
Old 06-10-2013, 06:05 AM   #2
SteveH's Avatar
Common Sense , Texas
Seem as though the Sewer Solution should work in that situation.
http://www.campingworld.com/shopping...solution/16617
Regards,
Steve
Old 06-10-2013, 06:06 AM   #3
Kevin245's Avatar
Have you considered a sewer solution system? You can portal waste through a 1 inch diameter PVC pipe. This isn't a roll up hose application but it is significantly smaller and less obvious than the standard stinky slinky.
www.sewersolution.com
Eleanor Roosevelt
Old 06-10-2013, 06:09 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Multiple connected sewer hoses. Or sewer to Suspended off ground PVC. Or mix of both.
For our stinky slinky I cut ridged landscape drain line lengthwise in half. It is rigid enough to support loads with minimal supports. Just spread the pipe and pop in the slinky and chock for support or use some sections of the accordion style support.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-10-2013, 06:22 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
With a 75' run, the Sewer Solution is the most viable solution for this situation. The Sewer Solution flexible hose is only 1" in diameter and green in color. If necessary, it could be rolled up and put out fairly easily.
Brian
SuEllyn & Brian McCabe
Old 06-10-2013, 06:24 AM   #6
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I would also vote for the Sewer Solution. As I recall it comes with 10' of 1" vinyl type hose with a slip on ferrule that accepts additional length hose. I think Lowes or Home Depot sells suitable 1" clear tubing by the foot off a roll. The length should not be a problem as you say it is generally sloped downhill. You may find it an advantage to taking the SS with you on your other trips in the future as I have found it very handy in those cases where the campground's dump port is uphill from the trailer's outlet.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-10-2013, 06:57 AM   #7
Wow folks- thanks for the replies.
As for the SS...I see the hose is 1", is that sufficient diameter to allow waste to flow through?
Someone recommended I go to a pool supply place and get 75' of backwash hose and connect that with some fittings. And then I could roll that up like a fire hose.....what do u guys think?
Old 06-10-2013, 07:20 AM   #8
moosetags's Avatar
Yes, the Sewer Solution handles all black tank waste very well. We have been using it exclusively for the last 5 years, during which we have camped in our Airstream for over 1,000 nights.
Brian
Old 06-10-2013, 07:52 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sewer Solution recommends using 1" PVC pipe for long runs up to 100' but I would think a smooth 1" flexible hose would work as well.
It's a good, clean, compact system, have used it for over 700 camping days and it works as advertised.
doug k
Old 06-10-2013, 08:13 AM   #10
2008 27' Classic FB
Burkburnett , Texas
Unlike a macerator, the SS uses city or pump water pressure (15 psi min) to inject a pinpoint jet of water into the Venturi housing that effectively liquifies any solids that are appropriate for the BW holding tank. The force of the jet is enough to maintain flow uphill through the 10' discharge hose, they claim 3' but I know from personal experience it will do at least 18".
Go to their website and look at the explanation and diagram of how it works. Their FAQ also claim 100' discharge on level ground and longer if it slopes downhill. On a downhill slope, I don't see a problem using a larger diameter discharge hose, but a 1" hose may be less expensive and easier to roll up and tuck out of sight.
AIR 47751
Old 06-11-2013, 01:13 PM   #11
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Not good for boondocking since you need to use water to make it work
beetlebob is offline   Reply With Quote
Old 06-11-2013, 01:25 PM   #12
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A macerator pump is still an option. It only uses the water that's in the holding tanks; dump black water first, then gray water to clean the hose. Not as good as SS, but at least you don't have to add more water in order to discharge.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-11-2013, 01:39 PM   #13
daveswenson's Avatar
2012 28' International
Issaquah , Washington
The OP says he has full hookups so water isn't an issue.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-11-2013, 02:33 PM   #14
dkottum's Avatar
You most probably would not dump while boondocking until you get to a dump station, which has water.
doug k
