Old 01-07-2013, 06:42 PM   #1
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes , Texas
XC360 Engine Bay
Over the past 50 years I have had numerous street rods and classic cars with detailed engine bays
After having the mh for a year now, I finally raised the bed and looked into the engine bay Is there any way to clean the engine compartment or do I just not look at it
lsmith is offline   Reply With Quote
Old 01-07-2013, 06:46 PM   #2
SteveH's Avatar
Common Sense , Texas
Do like I do with my truck....take it to a quarter car wash.
Regards,
Steve
Old 01-07-2013, 08:39 PM   #3
rosewoodtx's Avatar
1977 Argosy Minuet 6.0 Metre
1997 30' Excella
San Antonio , Texas
spray it with some cleaner and do as steve suggests. also, why is it so dirty? oil leaks, exhaust leaks?
rosewoodtx is offline   Reply With Quote
Old 01-08-2013, 07:16 AM   #4
SteveH's Avatar
All kidding aside, Larry, you could take it to a car wash that had one of the high bays, snake the wand in thru a window, and have a helper operate the coin slot machine.
If you need someone to help, I would be happy to help you.
Or, I have a pressure washer that I could bring over, and it would be basically the same procedure only the helper would be operating the pressure washer.
Regards,
Steve
Old 01-08-2013, 09:42 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Maybe we could wash it like the kids in the Subaru commercial
Like Steve said, seriously is it oil leaks or just raod grime. I would think that not much road dirt would get up in there.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-08-2013, 11:24 AM   #6
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
On my Clipper I had the return fuel line fail in a remote area in Northern Ontario in 2011.
http://www.airforums.com/forums/f313...ml#post1043624
We had some gravel roads before and after that and the engine, rad, and bay area was covered with a nice fuel/dust stucco.
On return to base I used the garden hose to dampen the affected area, and then hand sprayed with a quality marine brand degreaser. Then rinse off with the garden hose. Some corners and holes required a second application.
Do not use high pressure around your rad and ECM cable connections.
Dave
Old 01-08-2013, 03:39 PM   #7
Helotes , Texas
No oil or fuel leaks, just dirt and dust. My interest was what do you cover, ie electronics, carpeting around the bed etc I am sure with a hose with any pressure will have overspray
