Old 04-23-2012, 07:55 PM   #1
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
Window Seals
Most of the rubber window seals on the windows on our Cutter Bus have shrunk, leaving the windows vulnerable to leaking (fortunately we live in an area that only sees rain two or three times a year). The large side front windows have the worse shrinkage of all, and just spraying a hose on the front of the motor home will allow water to leak in.
I'm willing to replace the rubber molding all around, but I'm not sure where to buy the molding..suggestions?
dgmelp is offline   Reply With Quote
Old 04-23-2012, 09:08 PM   #2
1986 31' Sovereign
Miami , Florida
Got mine from Inland RV -- went with the newer "D" shaped gasket material. They will also sell you the black 3M adhesive.
Removing the old gasket is tedious but lots easier with some 3M Adhesive Remover (I got mine from an automotive paint shop) and a good scraper.
We did all of our windows in a long day. Nice and tight now.
mike
