Old 03-03-2011, 12:26 PM   #1
1998 30' Cutter Bus (Chevy)
Sarasota , Florida
Wheel well plastic
Hello all; I own a 98 30ft cutter, left rear inboard tire blew and damaged
the plastic wheel well cover. I had considered a repair, but too many pieces
missing. Does anyone know of a source for cutter body parts? Does
Thor provide parts for the older airstreams? Any suggestions will be
appreciated.
We have owned this RV since 2006, fulltimed for 4 years, now taking a
year off before hitting the road again. We have had no major problems with
the RV except wringing our hands over the shoddy wiring, plumbing etc.
Thanks, Jim
jcessna is offline   Reply With Quote
Old 03-03-2011, 01:26 PM   #2
appreciated.
Thanks, Jim
Checking on it for you.
Old 03-03-2011, 02:21 PM   #3
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Try Colaw Rv salvage in Carthage Mo they might have one
osolow is offline   Reply With Quote
Old 11-19-2011, 07:31 PM   #4
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
Wheel well cover
appreciated.
Thanks, Jim
Jim,
Did you ever find replacement wheel well covers? We have two covers that are partially damaged and we're not sure what to do with them - if you did, would you let us know where you found them - or if you repaired them, how did that work out?
We have a 1996 30 foot Cutter Bus - just want to get these fixed if possible.
David
dgmelp is offline   Reply With Quote
Old 12-12-2011, 08:56 PM   #5
Sarasota , Florida
Hi David; As you can see I don't check this site often. I called Airstream
they advised me to contact an Airstream dealer, the wheel well covers
are in stock but must be purchased through a dealer. I haven't replaced mine yet. Jim
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Plastic Window Knobs or Crank boutdoors Windows & Screens 0 05-09-2011 04:08 PM
Plastic Waste Tank Patch silversafari Waste Systems, Tanks & Totes 8 03-03-2011 06:53 PM
