Old 07-19-2013, 01:42 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
What wood is this?
I am doing some remodeling and need to match the wood in my 2005 396 XL. It light colored but not pine or oak. I have been told it might be Ash. Here is a picture of the kitchen cabinets.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-19-2013, 01:51 PM   #2
2002 19' Bambi
Lafayette , California
Looks like the hickory Airstream puts in the Classic model trailers.
Tim
Tim A. is offline   Reply With Quote
Old 07-19-2013, 02:44 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yes, that looks like hickory.
Chris
Old 07-19-2013, 02:49 PM   #4
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
Looks like hickory. Remove a door and take it to a local cabinet maker.
tarnished is offline   Reply With Quote
Old 07-19-2013, 03:20 PM   #5
SteveH's Avatar
Common Sense , Texas
Looks just like the Hickory in our '10 Classic, and it has a lacquer type finish, not oil base varnish.
Regards,
Steve
Old 07-19-2013, 04:11 PM   #6
adonh's Avatar
1976 31' Sovereign
I think everyone is right, hickory. Now I need to find a source to buy some 1"x4' boards and a peice of hickory veneer 1/4" plywood. There are a few stores here in Houston that carry hardwoods so I will start there first.
Don Hardman
1976 31' Sovereign
Old 07-27-2013, 06:08 PM   #7
adonh's Avatar
1976 31' Sovereign
I found my Hickory and I am about ready to put the finish on. I am wondering if something like this Minwax clear brushing lacquer would be what I I need. This is a gloss but I assume a semi gloss or satin would also be available. I would like to stay with the same type of finish as the ithe other wood. Thanks for an y input.
Minwax 1-qt. Gloss Clear Brushing Lacquer-15500 at The Home Depot
Don Hardman
1976 31' Sovereign
Old 07-27-2013, 10:19 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
You might call the factory ((937) 596-6111) and ask what finish they used on the 1976 Hickory interiors so the end results match the rest of the trailer.
Wood Stove in the Cruiser tinman54 Furnaces, Heaters, Fireplaces & Air Conditioning 12 01-12-2012 03:22 AM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
Front Door Wood Floor is Wet lmcatee Interior Restoration Forum 6 10-04-2011 01:45 PM
Feast of Spring Rally at Penn Wood Airstream Park PA Camper WBCCI Rallies & Events 0 04-06-2011 06:14 PM
Workamping Opportunity At Penn Wood Airstream Park DEITZ645 Working on the Road 0 03-14-2011 11:58 AM
