Old 07-28-2013, 09:53 AM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Voltage meter intermittent high
When my engine is idle the voltage is high on my meter,and when i move it is,ok
The alternator is new,is the battery isolator could be my problem
Cutter 99
Marc
landmarc is offline   Reply With Quote
Old 07-28-2013, 10:06 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Not sure what you are saying here. The alternator will put out 15+ volts if demanded by the sense circuit location. (my Clipper has a Delco 3 wire)
If you are still using a battery isolator, chances are the alternator is being asked for full production at all times, as there is no physical method of controlling the demand of the house and chassis battery demands.
I have upgraded my systems to use SurePower 1315-200 battery separators controlled with solenoids, to allow manual override of demand on the chassis alternator.
http://www.airforums.com/forums/f313...ml#post1107521
Are you having battery charging problems? If not, it may just be the gauge or a poor ground at the gauge???
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 08-03-2013, 09:12 AM   #3
Rimouski , Quebec
I check my voltage onthe battery and it,s good,13,9 v
The meter have variation from 16 to 14v
The problem is,to find the meter ground
Marc
Old 08-11-2013, 07:04 PM   #4
Rimouski , Quebec
When i am driving down the road the volage gauge indicate very high,and when i up the gauge indicate normal
