Old 02-24-2016, 05:03 PM   #1
TorpedoFamily
Torpedo Family's Avatar
2005 30' Classic
Ozark , Alabama
TV antenna
I want to put a over the air antenna on the outside of the MoHo and can not get any signal from the outside jack to the television. Is this for CABLE only? Does it need boosting? I will share the results when accomplished.
Torpedo Family is offline   Reply With Quote
Old 02-24-2016, 05:33 PM   #2
SteveH's Avatar
Common Sense , Texas
Ours came with the roof mounted antenna. It is over the bedroom. The push button switch on the coaxial cable output plate that turns on the little LED light switches from cable to the antenna. Light on=antenna. Light off=cable.
Regards,
Steve
Old 02-25-2016, 11:23 AM   #3
israndy's Avatar
2005 39' Skydeck
Alameda , California
Technically I believe that light indicates amplification of the antenna, certainly by NOT amplifying it you will have less interference with the cable signal, but I do not believe it is a switch. If you have a signal pulled in to your analog tuner on your TV (that no one has anymore) and you turn the light out it will get snowier, but it will not go out. Now since we all have digital TVs tuning digital TV stations you will likely see the signal be fine and then there is no signal when the light is out, but you are just as likely to have signal and continue to have signal when you turn the light off as the digital signal is really strong in most cities.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 02-25-2016, 12:19 PM   #4
SteveH's Avatar
Actually, the light does indicate power applied to the antenna amplifier, but the button also switches input between antenna and cable.
Regards,
Steve
Old 02-25-2016, 04:01 PM   #5
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Have you tried the TV directly to that antenna, without going through the M/H cable(s)? Could just be antenna alignment. The digital bands are so narrow, moving our roof mounted antenna 1/2" can lose/gain signals. If the M/H cable passes a cable TV signal, it ought to pass an antenna signal (once proven to be there).
Hope this helps.
ShinyPete is offline   Reply With Quote
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
