Old 05-01-2013, 10:13 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Toilet Paper
Looked around the forum some, but...
CP is buying TP from CW. But has anyone had good luck with grocery store TP that won't clog or cause problems with the Black Tank and/or sewer line?
Did see some posts that there is a spray Black Tank connection - have to see if we have that on our Clipper.
JourneytoRet is offline   Reply With Quote
Old 05-01-2013, 10:54 AM   #2
Zanadude Nebula , Milky Way
Put the TP in a jar, fill half way and shake, if it breaks down in a couple hrs it's good to go....literally.
DW is in charge of all things sanitary...can't recall what is being used now.
"who used the last of the TP and didn't put a new roll on"
but Iím the Husband, so we went to Cleveland.
Step aside Starbucks, this is a job for alcohol.
Old 05-01-2013, 11:42 AM   #3
dznf0g's Avatar
Oswego , Illinois
In both of my trailers, I have never had ANY problem with prudent use of ANY TP.
I just make sure I keep plenty of fluid volume in the tank. Another beer, please!
Old 05-01-2013, 11:49 AM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I have been using Scott single ply for 9 years, no clogs yet
"Chip Tank" is in Hope Az.
CDONA is offline   Reply With Quote
Old 05-01-2013, 11:58 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have never had any problem with any decent toilet paper in over 40 years.
That may not be the case with the stuff out of the sandpaper factory, but you don't want to use that anyway.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-01-2013, 12:06 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
avoid "Extra Strong"
The shake in a jar of water is an excellent test. Also look for septic tank safe somewhere on the packaging.
The cheaper the better - the ones with lotion, aloe, or extra strength will clog. If you are traveling, anything in the black tank will be shaken to a slurry if you have enough water in the tank. If you camp for a couple of weeks at one location, then problems can crop up or worsen.
Kleenex tissues (or any other brand of nose wipes) are designed to hold together much more than TP, so don't use them just because you're out of TP.
If you ever do get a paper clog, don't forget that throwing about 5 lbs of icecubes down the toilet followed by a long ride down a coutry road will scrub anything out (other than the Barbie Doll head your nephew put down there).
Foiled Again is online now   Reply With Quote
Old 05-01-2013, 12:26 PM   #7
1988 25' Excella
Trumbull , Connecticut
Toilet Paper
Hello All. I like the Costco Kirkland brand TP because it is a 2 ply and therefore stronger than the Scotts 1 ply. I tried both in the water in jar test and the Costco brand and Scotts brand are equal in the disolving quickly department.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 05-01-2013, 12:30 PM   #8
mandolindave's Avatar
You can get it everywhere at a reasonable price. It breaks down as well as any " RV " TP
mandolindave is offline   Reply With Quote
