Old 12-31-2009, 08:33 AM   #1
1996 34' Cutter Bus w/slide
murphy , North Carolina
Stripe kit?
where can i but a new stripe kit for my 1996 cutter 34 ft? can anyone tell me where to look thanks
scotter is offline   Reply With Quote
Old 12-31-2009, 08:44 AM   #2
Chasmorgan's Avatar
1999 23' Safari
Purchased striping for my 99 Safari from: RV Tips and Tricks. Good Luck!
Chasmorgan is offline   Reply With Quote
Old 01-08-2010, 10:39 AM   #3
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
If you have any sign or graphic design companies in your area, contact them.I was told by one in my area to bring the coach in and they could stencil over existing striping and make one to match. Don't know the cost involved, I haven't followed through on having it done yet. You could also try contacting AirStream, a while back they told me they sometimes have access to some older striping,or might point you in the right direction.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 01-08-2010, 11:45 AM   #4
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I was able to purchase replacement graphics for my 1995 28 Classic, by contacting an Airstream dealer.
ArtStream is offline   Reply With Quote
Old 11-19-2011, 07:44 PM   #5
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
We just had our 1996 Cutter Bus completely re striped by a company in Apache Junction, Arizona (part of Mesa and Phoenix) - RV Stripes and Graphics. (www.rvsg.com).
Talk to Dale - he did an outstanding job removing all the old graphics and reapplying new graphics in our choice of colors, but exactly covering the same area the old graphics covered, eliminating any ghosting effect you will have if you don't cover the areas you remove old stripes from
He also printed and mounted an original graphic my wife designed for the back - very happy with the job. We'll be happy to send anyone that likes pictures.
dgmelp is offline   Reply With Quote
Old 11-20-2011, 08:25 AM   #6
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , South Dakota
We removed the old vinyl ourselves and a local sign shop cut and installed the new vinyl for us. The cost was somewhere around $2000. The removal is very labor intensive. If you decide to do the removal yourself, I could give you some tips on tools and technique.
Here's a little video we made http://www.youtube.com/watch?feature...&v=EzJOqrvEYD0
BarnacleBill is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Lift Kit palmtreegirl Jacks, Stabilizers, Lifting and Leveling 4 10-12-2012 07:21 PM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 01:15 PM
Chris Craft Kit Travel Trailer not Airstream or Century eBay Watch Airstreams on eBay 0 03-17-2011 11:30 AM
