Old 04-20-2016, 09:13 AM   #1
2004 39' Skydeck
Green Cove Springs , Florida
SKYDECK roof covering
I just purchased (not installed yet) some of the original roof deck floor covering 3M safety walk slip resistant medium resilient tape, self stick, Grey 370, 24X60 roll.
Got it from JobberPAL.com Part #70070549236 $516 for 60 ft roll.
Thanks to southerncoachrv.com for the information. (they installed it on their skydeck already)
Will post pics once i get it installed.
Alan
Big Blue Rv is offline   Reply With Quote
Old 04-21-2016, 03:03 PM   #2
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
That what I have in mine not to happy how it was installed and now I saw it's coming loose again after less then a year.
Peter
PSchw is offline   Reply With Quote
Old 04-23-2016, 09:04 AM   #3
israndy's Avatar
2005 39' Skydeck
Alameda , California
Mine is completely gone, but I got the RV 10 years old, so no idea when it came off. I am in no hurry to replace, although it did protect the fiberglass from the sun. Now that summer is coming again I need to wax the fiberglass to protect it from more micro-cracks.
It is disappointing that the new roll peels back up so quickly. Perhaps we need to look to the yacht industry for guidance. I have seen they actually use a form of paint to put the rough surface on their decks to keep people from slipping. Although as it stands the surface is really easy to clean. Might need to get a power washer to clean a rougher surface.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 05-07-2016, 08:20 AM   #4
PSchw's Avatar
Livingston , Texas
I prepped the roof for the coating. After digging into it it is not that bad.
Most parts are either screwed or rivet on.
Here some pictures:
Name:   ImageUploadedByAirstream Forums1462629645.224559.jpg
Name:   ImageUploadedByAirstream Forums1462629668.031626.jpg
Name:   ImageUploadedByAirstream Forums1462629692.119377.jpg
The rear seat backrest holder is challenging as you have to remove the complete framing to get the screws in and out😨
Name:   ImageUploadedByAirstream Forums1462629829.054718.jpg
Name:   ImageUploadedByAirstream Forums1462629954.455618.jpg
The backrest in the rear was riveted on in wood😱
Name:   ImageUploadedByAirstream Forums1462630073.706609.jpg
I have stress cracks and rivets worked then self loose
Name:   ImageUploadedByAirstream Forums1462630234.945757.jpg
Name:   ImageUploadedByAirstream Forums1462630319.290584.jpg
The backing on the cushion are wood which in some area is rotten away. The foam does not look to good either.
Name:   ImageUploadedByAirstream Forums1462630470.227070.jpg
Name:   ImageUploadedByAirstream Forums1462630529.619468.jpg
Name:   ImageUploadedByAirstream Forums1462630590.143042.jpg
Looks like that all I can upload.
Peter
Old 05-07-2016, 01:58 PM   #5
israndy's Avatar
2005 39' Skydeck
Very nice. I see you are uploading low res photos, so I cannot see the detail but your cushions look better than mine. At least a large chunk of their lives were spent indoors. When I get mine redone I will probably only put them out when I am going to use them. Leave them in the basement the rest of the year. The foam will probably always look bad as it is not designed to be comfortable, it is designed to shed water out the holes in the bottom of the cushions. If it absorbed water it would be mold city in there. I don't actually have any new foam, so it may be weathered.
What's the next step? Are the sides coming off? The furniture? Loving the photos, thanks so much.
-Randy
Old 05-08-2016, 06:47 AM   #6
PSchw's Avatar
Livingston , Texas
That is all for me. Rest will be done by MasterTechRV.
The front and the rear will have adaptor plates do you can remove it without destroying the roof seal.
The center I will leave and they will be costed over.
Name:	ImageUploadedByAirstream Forums1462711241.800910.jpg
Name:	ImageUploadedByAirstream Forums1462711268.027406.jpg
ID:	262121Click image for larger version
Name:	ImageUploadedByAirstream Forums1462711297.266131.jpg
Found another loose antenna cable behind the roof entertainment center.
I guess they only used part of the cable.
Name:	ImageUploadedByAirstream Forums1462711434.117719.jpg
Name:	ImageUploadedByAirstream Forums1462711475.772642.jpg
Name:	ImageUploadedByAirstream Forums1462711506.944425.jpg
Peter
Name:	ImageUploadedByAirstream Forums1462711323.308181.jpg
Old 05-08-2016, 10:36 AM   #7
israndy's Avatar
2005 39' Skydeck
Yeah, my antenna is missing too. I got OK reception of the Reno Air Races signal but I was feet from the tower. I have already purchased several antenna to replace that one, hoping to find one that just screws on that part, but I have yet to find a fit. It needs to pivot on the other side of the fiberglass so the mast stays up and down instead of sticking straight out sideways. I don't believe there is any paint damage of the outside of my fiberglass so perhaps neither of our RVs ever had the mast mounted. They attached the inside part of the antenna but never the mast.
I am actually missing an antenna above the passenger seat too. There is a hole in the fiberglass right there, and others have antennae there, but I do not. I removed the vent right there and stuck my iPhone thru and took pictures and didn't actually see any inside part of an aerial, so perhaps I get my FM antenna from the omni TV antenna next to the front A/C. I also noticed that I am missing the antenna above the driver's seat, I believe that is for CBs, and I don't have one. I have seen others with an antenna there too.
You know, putting your photos away in my Photos app I noticed your RV looks JUST like another Masseyfarm posted about:
http://www.airforums.com/forums/f313...ml#post1395038
Wonder if it's the same one?
-Randy
Old 05-08-2016, 09:14 PM   #8
israndy's Avatar
2005 39' Skydeck
Aha! OK, so there IS only 1 Skydeck with your paint job, pretty common, usually if I see the same paint, it's the same Skydeck, unless it's red like mine, there's at least 3, or blue Nascar, there's more than one, maybe 4 or more.
I know yours is the same as the one posted on the RVs for sale thread because of this thing your RV has in common with that one. The satellite tower that raises with the rail. Yours has the same damage to the stereo cabinet table.
Personally that seemed clever, I might have kept that feature. Although you also might put one under the fiberglass crown as that seems to work well too. No wasted space on the deck. That's down the road for me someday.
-Randy
Name:	2006 Skydeck 1.jpg
ID:	262170   Click image for larger version
Old 05-09-2016, 06:10 AM   #9
PSchw's Avatar
Livingston , Texas
Yes that is mine now.
The title says 2006 but it is a 2005.
Peter
Old 05-20-2016, 04:23 PM   #10
PSchw's Avatar
Livingston , Texas
Here what it looks like now
Name:	ImageUploadedByAirstream Forums1463782784.808850.jpg
ID:	262833Click image for larger version
Name:	ImageUploadedByAirstream Forums1463782801.511848.jpg
ID:	262834Click image for larger version
Name:	ImageUploadedByAirstream Forums1463782821.764452.jpg
ID:	262835Click image for larger version
Name:	ImageUploadedByAirstream Forums1463782837.532631.jpg
ID:	262836Click image for larger version
Name:	ImageUploadedByAirstream Forums1463782865.619975.jpg
Hope it's done o a couple of weeks.
Had to do the cushions too as the back was rotten.
Name:	ImageUploadedByAirstream Forums1463782961.316541.jpg
ID:	262838Click image for larger version
Name:	ImageUploadedByAirstream Forums1463782981.902750.jpg
Peter
Old 05-20-2016, 07:22 PM   #11
israndy's Avatar
2005 39' Skydeck
Wow! You got all the seats off! Do you know how they came off? I see only holes in the top that I guess had bolts thru them. Is that all? Just a bolt thru the bottom of the furniture and into the roof support? That would make it pretty easy to remove, but also pretty easy to leak.
And you got the rails off, wow! Not sure why the lifts are still in place, and that aluminum panel where the stereo was. I can see leaving the stair cover as you are going to seal it to the roof, like you are with the plumbing vent above the washer/dryer.
I cannot get over how nice it is that you are down to the basics. As soon as I am sure I will be keeping the Sky Deck I will follow in your footsteps. I have to get the mold under control first. Once you get the roof sprayed you will be protected from cap to cap. I am really excited to see the results. When you are done you may want to look into protecting your gutter. I found these foam gutter filters that allow your gutters to stay clean by keeping big objects out:
They are triangles so they would take the roofline straight against the wall. If the big things don't just blow away when you drive you can take the filters out periodically and shake them over the edge.
Are they recovering the cushions? Or just putting a new bottom on them?
-Randy
Old 05-21-2016, 09:21 AM   #12
PSchw's Avatar
Livingston , Texas
Great idea with the gutter stuff. If it is all sprayed the gutter will covered over so there is no more the small canal it will be big and wide and everything will flush out either in the front or in the back. At least this is the idea.
All the bracket are mostly rivet on and yes a big concern of leaks.
I have bracket manufactured which seal to the roof and the seat brackets will be screwed on top and are removable without breaking to seal.
Have also new seat and backrest made as most of the wood is rotten. The new seats have a honeycomb plastic backing s o sacking over the rear a/c and now rotting.
The water line coming out of the roof is and always was to short could not being sealed correctly now it's gone be fixed.
The deck will be better then new.
Peter
Old 06-09-2016, 07:27 PM   #13
israndy's Avatar
2005 39' Skydeck
Any news? Other than new Class A's from Airstream.
-Randy
Old 08-17-2016, 09:07 AM   #14
PSchw's Avatar
Livingston , Texas
Here is my "new" roof.
Name:	ImageUploadedByAirstream Forums1471445292.166185.jpg
ID:	269292Click image for larger version
Name:	ImageUploadedByAirstream Forums1471445309.865494.jpg
ID:	269293Click image for larger version
Name:	ImageUploadedByAirstream Forums1471445323.815364.jpg
ID:	269294Click image for larger version
Name:	ImageUploadedByAirstream Forums1471445337.885588.jpg
ID:	269295Click image for larger version
Name:	ImageUploadedByAirstream Forums1471445354.085985.jpg
MasterTechRV did a horrible job in details. Never really finished it up lost internal covers cut internal covers unsightly.
Name:	ImageUploadedByAirstream Forums1471445470.187455.jpg
Name:	ImageUploadedByAirstream Forums1471445531.361005.jpg
Name:	ImageUploadedByAirstream Forums1471445564.115199.jpg
MasterTechRV is not worth to even work with the just done care. They have also time Managment issues av4 week repair took 3 months cost me several hundreds on cancelations and screwed up all our plans for summer.
Keep in mind I start this process in January to make an early reservation to be proactive and give them plenty of time to schedule well.
As I said they don't care.
The upholstery turned out ok, guess the use a sub with higher quality standard the MasterTechRV.
I guess it is not easy to get anything done good and I did not look for cheap the roof rebuild or recovering was $25k.
They also replaced a basement door. They said they can make it exactly like the original on. Should be no problem if you can measure.
Name:	ImageUploadedByAirstream Forums1471446191.218188.jpg
Name:	ImageUploadedByAirstream Forums1471446211.522411.jpg
I guess they cannot measure as the picture shows.
Name:	ImageUploadedByAirstream Forums1471446265.079763.jpg
New door 3 times drill all the holes to get it wrong.
So now I paid for the guys time and have a all this holes in my new door I paid $1,200 for.
So overall my recommendation stay away from MasterTechRV in Elkhart IN.
Peter
Skydeck ?? Rod Pease Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 18 05-06-2016 11:55 AM
Airstream SkyDeck MH!!!! ViewRVs Airstream Motorhome Forums 7 02-23-2016 10:15 PM
Used Skydeck Airstream 330hp Diesel RoofPatio Motorhome SUsed Skydeck Airstream 330hp eBay Watch Airstreams on eBay 0 11-28-2010 05:50 AM
Used Skydeck Airstream 330hp Diesel RoofPatio Motorhome SUsed Skydeck Airstream 330hp eBay Watch Airstreams on eBay 0 11-19-2010 06:10 PM
Who owns a A/S Skydeck? docbluedevil General Motorhome Topics 9 01-10-2005 09:04 PM
