Old 09-05-2016, 12:14 PM   #1
israndy's Avatar
2005 39' Skydeck
Alameda , California
Rusty Side Mirror repair
Is anyone else suffering with rust on their very expensive side mirrors?
I have to take it apart to get the rust completely off and refinish it. First step, get the right screwdriver.
That's a Phillips #3. I had to use vise grips to spin them. Actually I had to use a rust penetrant and a hammer first. Then the wrench to hold the screwdriver while I pressed in with all my might.
Once I got them spinning, they just kept spinning. Turns out they have lock nuts holding them in place.
I finally ended up using the vise grips to grab the nuts, but to keep the wrench from spinning I duct taped a broom handle to them.
Still have to remove the wires feeding the mirror and they are short. Since I had not unhooked the connector inside and it was too short to pull out I re-hung the mirror by a couple of screws only.
Then I could use both hands to unhook the connector. There is the wrench with the broom handle.
The other wire is likely for the light as it is wired into the turn signal part of the headlight. It is long enough that I could lower the mirror to the ground.
After removing the electrical tape I found the wires were crimped in place. So I will need more tape and wire crimps when I go to put this back.
I know, I didn't do much, but I wanted to document it in case anyone else ever has to face this. Also, so I can remember the steps to put it back together... Next step is finding someone willing to re-chrome the base and the arm. Easier now that I can just drop it off.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: March 2018 Tesla Model ☰, a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles
israndy is offline   Reply With Quote
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
Mirror, mirror off the wall! Pudentane General Repair Forum 2 08-09-2009 07:28 PM
Mirror Mirror on the wall early General Interior Topics 2 11-20-2005 09:13 PM
Mirror Mirror on the wall.... GT1963 The Pet Forum 9 03-15-2004 08:42 AM
Rusty screws in side windows (galvanized) Orland Dewey Airstream Motorhome Forums 4 06-17-2003 08:42 PM
