Old 11-02-2015, 06:19 AM   #1
SteveH's Avatar
Common Sense , Texas
Routine Service
I have searched this forum for the information I'm looking for without success, but does anyone here do there own routine engine service work, such as oil, and filters changes?
If so, do you have a source for the filters you could pass on to a motorhome "newbe"?
Regards,
Steve
Old 11-02-2015, 08:56 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Filters are available at any auto wholesale outlet, or any heavy truck dealership ----BUT ------ I have done this over the years, and I have refined this in later years.
If you are doing high mileage, and returning to your own shop regularly, it might be (is) worthwhile to develop your own support system.
But, a motorhome generally is not a high mileage unit.
I find my oil change intervals happen when I am in NY or CA or Dawson Creek BC, and I am not going to carry the gear to do that on the road.
Take you Diesel Pusher to any Heavy Truck Shop and relax with a coffee while they do a professional job, quick and clean.
The shop time consumer is greasing your unit. If you want to save the shop hour rate, grease your own unit. You can carry that air or battery powered grease gun, and you know you have got all the grease fittings. It also gives you a chance to inspect the dark side of your motorhome. I grease my CLIPPER every 2500 miles. (approx.)
When I go to the truck shop, I specify an "ENGINE OIL CHANGE" and a "COOLANT DCA READING" only, and find the cost makes economic sense.
If the coolant DCA is low, you then buy and change the 'charged' coolant filter at your convenience.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 11-02-2015, 11:03 AM   #3
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
To answer your question, Napa, or any other upper tier parts house can cross reference every filter on your coach. I used to use a lot of Donaldson filters servicing our Cummins 330/Allison 6 speed on our 2000 Dutchstar.
To echo Masseyfarm above, I gave up doing my own for just the reasons he states. Check out Speedco or similar "on the go" shops for big rigs too, like a Jiffy Lube for trucks. I ended up finding a local mobile/single bay shop guy that was reasonable as well.
ShinyPete is offline   Reply With Quote
Routine exterior washing vintage trailer? AKBambi Cleaning, Stripping & Polishing 5 10-12-2013 09:15 AM
Started the Clean and Wax routine today. Bruce B Clearcoat, Exterior Paint & Trim 12 03-20-2012 08:32 AM
Routine Maintenance on a '79 Sovereign Land Yacht jferrante119 1974 - 1979 Sovereign 8 12-04-2009 12:38 PM
routine service north Florida wdobni Commercial Listings 2 10-08-2007 12:29 PM
Gas appliances in an RV - routine maintenance lbrodsky General Appliance Topics 9 09-06-2007 03:17 PM
