Old 09-15-2015, 10:23 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Roof Cleaning
I don't want to make a rookie mistake on this one. What have you done successfully, and maybe unsuccessfully, to clean the roof of a MH parked under trees (not pine) please?
JourneytoRet is offline   Reply With Quote
Old 09-15-2015, 07:15 PM   #2
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
I cleaned mine just a few days ago but with the Skydeck it is different anyhow but I purchase a Ryobi pressure washer and it did a good job . Cleaned well with the soup and follow up with the straight pressure blast.
Peter
PSchw is offline   Reply With Quote
Old 09-16-2015, 06:37 AM   #3
What pressure is your washer set at please? Has anyone else have bad luck with pressure washing (leaks)?
Old 09-16-2015, 10:14 AM   #4
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
I just power washed my airstream trailer a couple weekends ago. My power washer is no fancy expensive machine and it has different spray pattern tips for different tasks. I'm thinking most probably have a similar approach but I don't know. I was able to apply soap to the trailer with the low pressure tip which basically runs at the same pressure as the hose supplied input from my house. The middle pressure tip is what I used to rinse it off and I stood with the spray tip at least 5-6' away from the trailer for rinsing. The roof is not that hard to reach using a ladder however waxing the roof is a challenge. I have been told not to use a ladder which rests against the trailer side however I have seen people use dense foam "pool noodles" to cushion the ladder if that is the only type ladder you have. If you keep the water spray at a 90 degree angle to the surface of the trailer you should not have to worry about forcing water between seams. Be careful of vents however.
kdickinson is offline   Reply With Quote
Old 09-16-2015, 12:44 PM   #5
israndy's Avatar
2005 39' Skydeck
Alameda , California
Leaning a ladder the trick is to balance and not put a lot of weight on the motorhome. If your weight is all going down you should be OK, but aluminum skin can crush and tear easily. All you need is to enlarge a rivet and you now have a leak.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 09-16-2015, 02:28 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I hear margarine can be used to loosen 'sap'... I wouldn't use it for anything else...
Next, I have a 'deck brush' from a Marine supply store... works great.. use automotive soaps as they will run down the sides of the MH..
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-16-2015, 06:03 PM   #7
PSchw's Avatar
Livingston , Texas
Not sure what pressure mine runs I think it said 1600psi it is a cheap Ryobi one for $119 did not expect any good results but worked better on then expected.
Peter
Old 09-27-2015, 07:19 PM   #8
Fresno , California
I used my pressure washer on full blast...we have the same RV. Mine held up just fine, so I'm hoping that means yours will too =)
LucasS is offline   Reply With Quote
1999 white metal roof cleaning advice needed Bassrats2 Roof 5 08-25-2013 09:10 PM
Cleaning the roof usa448 Cleaning, Stripping & Polishing 3 10-22-2008 11:16 AM
Walking on the roof - cleaning / inspecting Resorts Roof 24 08-11-2008 05:03 PM
Excella Requires Roof Cleaning Streamer1 Roof 6 10-18-2006 03:27 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
