Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 01-25-2020, 06:23 PM   #21
FishByFly's Avatar
2017 25' Flying Cloud
Fayetteville , Arkansas
My fourth switch is to the LED lights under the awning. Won’t know the lights are on unless the awning is open.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn
2023 F150 XLT
FishByFly is offline   Reply With Quote
Old 01-25-2020, 06:31 PM   #22
FishByFly's Avatar
I added small LED indicators so we would know if an outside light was on.
FishByFly
2023 F150 XLT
Old 01-25-2020, 07:11 PM   #23
2021 22' Bambi
Portland , Arizona
This is a great idea ! How did you integrate the LEDs?
hanschristia is offline   Reply With Quote
Old 01-25-2020, 08:05 PM   #24
FishByFly's Avatar
The LEDs are just direct wired to the switch. Drilled a small hole in the face place and pressure fit the lamp in place.
FishByFly
2023 F150 XLT
Little white rocker switches by door... JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 05-19-2013 12:23 PM
Rocker light switches at Entry Emh142 Lights - Interior & Exterior 13 08-04-2010 09:16 AM
I_C rocker panel switch does nothing / rocker switches sources for replacements myfirstrv Land Yacht/Legacy Motorhomes 2 11-06-2007 07:26 PM
Illuminated rocker switches nickcrowhurst 1987 - 1989 Excella 15 01-14-2006 02:44 PM
Rocker switches--still available? Chuck Electrical - Systems, Generators, Batteries & Solar 12 05-17-2005 12:52 PM
