Old 12-28-2005, 05:53 PM   #1
1997 33' Cutter Bus (Ford)
buffalo , New York
Remote water tank fill
I recently brought a 97 Airstream Cutter '34 back from Florida to Buffalo NY.
While I have the unit in a warehouse now I plan to do some travelling this winter.
The owners manual speaks about adding antifreeze to the water tank. As well I anticipate that RV parks will be closed or atleast not offering services.
Can anyone tell me how to add water to the tank through the reported remote tank filling point? I assume this is how one adds antifreeze as well.
Perry
Garages is offline   Reply With Quote
Old 01-05-2010, 06:20 PM   #2
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Was Your coach winterized when you brought it home from Florida ???
John H. is offline   Reply With Quote
Old 05-07-2010, 11:36 PM   #3
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Do you mean the gravity feed inlet on the outside wall of the MH or the pressure fill inside the side bin.
Regardless of which one, I understood it was not usual practice to freeze-proof the water tank itself - or the water heater - because it would take a lot of antifreeze. Instead, the water heater is drained via the drain plug and the water tank drain is opened. Driving around a bit makes sure there is no significant water left in the water tank.
If absolutely freezing conditions are expected, the only way to use the water system would be to have some form of heating of all sections of the system.
Hmmmmm. I now see the original post was dated 5 years ago, so I guess he knows all about it by now.
Tony Lee is offline   Reply With Quote
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Pressurized water tank eracism Fresh Water Systems 2 10-25-2002 06:09 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
