Old 03-06-2013, 06:59 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Quick Generator Question - Charging
May I assume that when the MH is running, that it is charging all (MH and Gen) the batteries?
If I run the generator alone, does it charge all the batteries?
And since I haven't travelled yet, when I hook up at the campground, does its service charge all the batteries?
JourneytoRet is offline   Reply With Quote
Old 03-06-2013, 01:46 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Your unit is newer than mine so you will have to check out how your own systems are set up.
In 96, the motor homes were set up -----
chassis engine/alternator charged the chassis and the house batteries through an ISOLATOR.
When the aux. generator runs on my CLIPPER (equipped with the PTS7000) it was originally set up to charge the chassis battery direct from the genset and the chassis batteries from the SMART inverter/charger.
http://www.airforums.com/forums/f313...ml#post1248638
It was originally set up to charge the chassis batteries direct from the genset and the 'HOUSE' batteries from the SMART inverter/charger.
"Sure Power Battery Isolator
Eliminates multi-battery drain when two or more battery banks are in a charging system, performs as well or better than existing factory installed components, designed to exceed OEM specifications"
Later production, I believe, eventually updated to electronic control but I am not sure in what year of production that was.
On my CLIPPER, I have updated my 3 BATTERY BANK systems to SEPARATORS and did away with the ISOLATOR.
"Sure Power Battery Separator
1314-200, 1315-200 and the 100 amp version 1314 & 1315 is designed for use in
multi-battery applications as a solenoid priority system to protect the chassis charging system from excessive loading while allowing auxiliary batteries to be charged."
https://sites.google.com/site/surepo...lator/Downhome
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
