Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 09-30-2017, 10:12 AM   #1
1996 35' Land Yacht Widebody
council grove , Kansas
Power jack problem with a 96 Clipper
Hello,
I was trying to level my MH with the power jacks.
The jacks first worked ok, then quit working, now the jack display
unit on the dash doesn't turn on, but the jack motor won't shut off
and runs continually. I disconnected the batteries to shut it off, and now
I'm "dead in the water" Any ideas?
thanks,
Merrill
merrillv is offline   Reply With Quote
Old 09-30-2017, 01:56 PM   #2
power jack problems
Hello,
Belay that last question, turns out, it's the starter that s running all the time, and not turning the engine over. It was kind of hard to tell, since i'm working on it myself, but, I called a mechanic and he says it's a starter problem. I'll repost when I'm further along.
Merrill
Old 09-30-2017, 02:19 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
Originally Posted by merrillv View Post
Hello,
Merrill
The pump and reservoir on the CLIPPER are located in the right rear compartment.
If the red light on the Power Gear Hydraulic levellers stays on, then you are probably low on oil in the reservoir. There is a screw off dip stick on top to check and add oil.
The three solenoid are also located there, above the reservoir.
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 10-01-2017, 11:11 AM   #4
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , New Mexico
Don't add hydraulic fluid with the jacks extended. You will over fill the system!
BarnacleBill is offline   Reply With Quote
Old 08-21-2018, 04:08 PM   #5
Jacks on 97 Clipper not working.
Hello Dave,
My jacks were working until the starter went out.
I replaced the starter and now it works fine, but the jacks don't work.
At first, when I turned on the powergear at the dash, the pump would run
when I pushed the up or down button, but the jacks didn't go down. Now,
after fooling with it for awhile the powergear light comes on, but when
pushing the up/down button, the pump doesn't run. If you jump the pump motor solenoid, the motor will run.
After reading one of your other replies, I took out the power gear control module and looked it over, but found no fuses in it.
Any assistance would be appreciated.
Merrill
'53 Clipper and '49 Curtis Wright.. Clipper JayDigger Vintage Kin 13 02-24-2015 08:21 AM
1950 Curtis Wright Clipper :: 1950 Airstream Clipper jrjackson Airstream Registry Discussions 0 11-11-2014 10:41 AM
Power Jack Problem muvywrtr Jacks, Stabilizers, Lifting and Leveling 24 08-30-2011 05:47 PM
CLipper :: 1953 Airstream Clipper 1953Clipper Airstream Registry Discussions 0 08-19-2011 08:31 AM
