Old 04-13-2016, 08:52 PM   #29
SteveH's Avatar
Common Sense , Texas
Don't know if it the right thing to do, but I lower the suspension, and then with the levelers in manual mode, I level front to back, and then side to side. I only lift the MH the necessary amount, no more.
Regards,
Steve
Old 04-13-2016, 09:04 PM   #30
israndy's Avatar
2005 39' Skydeck
Alameda , California
My quote for the roof was much less, they only quoted 6 hours to remove all the furniture and re-install it afterwards. They were offering to do the top in either Line-X or that RV Armor like stuff. Still came out to $12K.
I am seriously thinking about just using the DiCor Fiberglass Roof Coating. Probably just the exposed area. May need to clean the surface first.
Had a bunch of leaking before, but some DiCor sealant took care of that. I have one more leak to find in the front, maybe from the new windshield.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 04-14-2016, 08:33 AM   #31
lewster's Avatar
Naples, FL , Hood River, OR
Dicor has a new vinyl type roof membrane that you should have a look at. Very similar to what high end manufacturers like Newmar have been using.
Very low maintenance and comfortable in price to EPDM rubber but far superior.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-14-2016, 08:02 PM   #32
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Lew Farber
541-490-6357
I looked at the DiFlex II which does not work to well with the SkyDeck because of the traffic and the equipment installed on the roof.
Peter
PSchw is offline   Reply With Quote
Old 04-14-2016, 08:09 PM   #33
PSchw's Avatar
Livingston , Texas
-Randy
Yes it is not cheap but I always believed in "you get what you pay for".
The product is not so the problem it is the craftsmanship to put it on our interesting roof.
All seating will be removed and the liquid seal installed so it build a good and clean run off for the water on the sided too. This will flush the debris easier out and clues all the sides front and rear cover to the roof.
I was impressed with the eye for details and the passion for the job with MasterTech RV and it is not easy to find somebody who is not only treating it as a job, specially in times like now where more work is around then good craftsman.
Peter
Old 04-14-2016, 09:40 PM   #34
PSchw's Avatar
Livingston , Texas
That sound logic. I forget usually to lower the air suspension and sometimes I run out of lift in the front.
I read you not supposed to lift the wheels of the ground and sometimes I use wood under the wheels to pre-level it in extreme uneven lots.
Peter
Old 01-03-2017, 05:32 PM   #35
2000 39' Land Yacht XL Diesel w/slide
Garland , Texas
So, I think this question will fit in here. Has anyone taken the pump and reservoir apart on the power gear leveling system that would be on a 2000 390XL? I am wondering if there is a pickup line or something in the tank that could possibly disconnect. My landing gear will not deploy and I am in the process of troubleshooting. It looks like the solenoids are working as they should. The pump doesn’t seem to pick up the fluid.
cb23 is offline   Reply With Quote
Old 01-03-2017, 07:27 PM   #36
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Make sure your fluid is topped off.
I have some info here on checking the solenoids. Your problem of not drawing oil sounds to me more like solenoids not opening?
http://www.airforums.com/forums/f313...ml#post1163394
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 01-04-2017, 08:16 AM   #37
Garland , Texas
That is what I was thinking too, but I did check the solenoids and moved them around to make sure it was a stuck dump valve. I went so far as to disconnect the dump solenoid and activated the pump, I can hear the pump run, but it doesn’t sound like it is under a load, just free spins. The fluid level is right up to the fill location on the tank. I am about to disassemble the tank and see if there is anything there. I hope there is a filter or something at the end of the pickup that is blocked.
Old 01-09-2017, 05:00 PM   #38
PSchw's Avatar
Livingston , Texas
I had a similar issue last year on my 2005 SkyDeck.
The pump is a gear pump and in my case the the gear on the driveshaft was busted.
There is a modification available from the manufacture cost like $400 but comes with everything needed.
I had a local guy trouble shoot and install the replacement parts.
Peter
12 volt Power taken by our electronic toys idroba Computers, Internet & Satellite 0 09-01-2014 08:32 PM
Power Gear Leveling Control Airstream12557 Land Yacht/Legacy Motorhomes 3 04-08-2013 05:09 PM
A & E Leveling system lock-up ? drcharles2 Jacks, Stabilizers, Lifting and Leveling 1 04-11-2004 04:15 PM
hydraulic leveling system kooblekidz Airstream Motorhome Forums 4 02-27-2003 01:52 PM
Gear vendors vs Us Gear LKappenman Mechanics Corner - Engines, Transmission & More... 0 04-18-2002 08:00 AM
