Old 07-15-2012, 05:44 PM   #1
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
Passenger side rear view mirror loose
I have power outside mirrors, and the passenger side mirror suddenly started moving with the vibration of the motorhome, so much that I can't adjust it with the switch - instead, I have to stop, get out and push the mirror (the actual mirror assembly inside the black housing) up back into position so I can use it again.
Any thoughts? I can't seem to find an adjustment nut or screw to tighten this....
David
dgmelp is offline   Reply With Quote
Old 07-15-2012, 09:27 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
We need a picture of the mirror for id.
Once we know what mirror it is, there should be a parts list and breakdown available.
Is this it?
https://secure.velvac.com/checkout/f...?parent=713858
Dave
David
Old 07-16-2012, 07:43 AM   #3
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
That is exactly the mirror that is on my motorhome.....
David
Old 07-16-2012, 08:41 AM   #4
masseyfarm's Avatar
Images: 56
Then go here and get your breakdown of parts and assembly instructions.
Velvac
This is specific to your model.
http://www.velvac.com/pdf/7094482.02.pdf
Dave
David
