Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 11-21-2011, 06:41 AM   #1
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
No power to 12v outlets on Dash
We have no power to the two 12v outlets on the lower part of the dash - this motorhome is new to us (1996 Cutter Bus 30ft) and we have only had it for about 3 months. We went to plug in a charger for our cell phones (and then tested it with other thngs like our GPS, etc) and found that both outlets are dead.
It appears all other outlets in the MH are fine. We can't find where the fuses might be for these two outlets. There is an electrical distribution box in the engine compartment which we haven't been able to check as we can't get the cover off (it appears there's some kind of catch underneath but we can't get it open).
So, this is two questions...where is the fuse for these two outlets, and how do we get that electrical distribution box open in the engine compartment?
By the way, we already checked all the fuses inside just behind the drivers seat and under the dash and all appear fine.
David
dgmelp is offline   Reply With Quote
Old 11-21-2011, 08:20 AM   #2
Mantua , Ohio
Sometimes these outlets only work when the ignition is on or the engine is running. jim
Old 11-21-2011, 11:16 AM   #3
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
Thanks Jim...but we were trying to use the outlets with the engine running - no luck.
David
Old 12-12-2011, 08:50 PM   #4
1998 30' Cutter Bus (Chevy)
Sarasota , Florida
The 110v distribution on our 98 Cutter travels up the left side of the RV
around the front then down the right side to the outlet near the door.
Our problem was the GFI in the bathroom acts like a circuit breaker. When
it opens there is no voltage up front, the kitchen is on a separate circuit.
The circuit is in series through the bathroom GFI, after replacing two
GFIs I installed a outlet box under the bathroom floor in paralell, so that the GFI only protected the bathroom outlet.
Hope this helps Jim
jcessna is offline   Reply With Quote
12v
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
