Old 03-23-2013, 06:00 PM   #29
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
I'm going out for the evening so will think about it and get back to you Don. What you describe does not sound like a sway bar rattle, but it might be a rubber bushing. Not sure how yours is set up. This is mine.
http://www.airforums.com/forums/f313...ml#post1119267
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-23-2013, 06:12 PM   #30
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
I am working on the grey water dump valve and the the city water pressure inlet that has a leak. While I was doing that I tried the handy little soap dispenser to clean my hands but it was corroded and stopped up. I cleaned it but it leaks just a little at the plunger at the bottom. It is a "Lions" brand but I can't find anything on the web. It fits in a little chrome holder and looks neat. I wonder if these are still available.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-26-2013, 05:16 PM   #31
adonh's Avatar
1976 31' Sovereign
passenger seat slideout floor
I am not sure what the actual name is but it is the floor that slides out to cover the stair well when the passenger is sitting in their seat. I know there is a lever by the door that activates this, open and close. I know that it worked on my trip back but I was going to show my wife how neat this today but nothing happened when I move the lever. So what did I do to cause this not to work while I have been parked in RV park with 50 amp power. I know I must have pushed a button somewhere when I parked last Sunday night that turned this off. Thanks
Don Hardman
1976 31' Sovereign
Old 03-26-2013, 08:04 PM   #32
masseyfarm's Avatar
Images: 56
Some other brands have that cover operated by AIR. I am not aware of how Airstream has theirs. Someone else might be able to help.
I see this in the owners manual Don. It is air operated.
AIRSTREAM 390/395/396 XL OWNERS MANUAL
C-16
STEP WELL COVER
Your motorhome is equipped with a pneumatically powered step well cover.
The switch (valve) is a black lever located in the front of the passenger right hand armrest. The
air pressure is supplied by the chassis air ride system. It is normal for the air system to leak down
so you may find the cover to be inoperable if the engine has been shut off for a period of time.
The intent of the step cover is to provide the passenger with a "floor" while traveling and then be
retracted so the steps can be used when stopped. With this in mind you can see where the loss of
air after the motorhome has been shut off for a time is not a problem. When you park the
motorhome you’ll normally retract the step cover so you can at least get out and stretch your legs.
If you happen to lose air pressure before retracting the step cover just starting the engine for a few
minutes will replenish the air supply.
! WARNING: Do not operate the pneumatic cover while standing in the step well.
Dave
Old 03-26-2013, 09:14 PM   #33
masseyfarm's Avatar
Images: 56
I can't imagine what it might be if it is under the dash and not below in the chassis area.
In the past, while underway, I have had my wife use the mechanics stethoscope to pinpoint a dull rattle in the TV cabinet that I was able to correct with some additional insulation.
I would think you could do something similar while underway with a cell phone . Have your partner tape his phone to a yard stick, then after calling you, hold his cell phone in the area of the squeak, to try to determine exactly where it is occurring. I would think you should be able to pinpoint it that way.
About the only movement below the dash should be the steering column that has a rubber weather boot where it goes thru the floor.
You have a front mounted slide out gen set that may be rubbing on something while underway. Did you check that area for obvious signs of chaffing?
Dave
Originally Posted by adonh View Post
Me and my friend were able to track down a few little rattles and squeaks along the way and fix them so it is pretty quite. Except what sounds to be under the drivers dash/instrument panel. On smooth roads it is only a small squeak,like rubber on rubber, not a wind noise. But on a rougher road its like 2 squirrels fighting. I crawled under there today with a flash light and see a lot of wires and stuff but nothing that I could see that would do this. Any thoughts.
Don
Old 03-27-2013, 02:54 PM   #34
adonh's Avatar
1976 31' Sovereign
Dave
I crawled under the front of the coach today and the only thing I see that may be causing this is generator muffler pipe that is touching a part of the frame when I moved it it rubs on the frame. There is a strap at the end that come out from under the coach with a metal clamp on the pipe and a rubber piece that attaches to the frame. If I could find something like this it would keep the pipe off of the frame. I guess all I can do is to try and eliminate things.
Don Hardman
1976 31' Sovereign
Old 03-27-2013, 02:57 PM   #35
adonh's Avatar
1976 31' Sovereign
If you happen to lose air pressure before retracting the step cover just starting the engine for a fewminutes will replenish the air supply.
Dave
That was it, started it up and after a few minutes it worked just fine. Thanks Dave
Don Hardman
1976 31' Sovereign
Old 03-27-2013, 10:11 PM   #36
masseyfarm's Avatar
Images: 56
I see you have the C7 engine in that Don, so you should have the advantage of all the programing that allows for this engine.
Dave
I am not a CAT man so I am having trouble determining what engine you have. Is that the C7 or is it the 3126 model? I believe both were commonly rated at 330HP. If you have the bed up, the engine ID stamp should be on the street side of that engine. Dave
Old 03-28-2013, 06:19 AM   #37
adonh's Avatar
1976 31' Sovereign
Dave
Yes it is the C7 so I will try programing that you included earlier
Don Hardman
1976 31' Sovereign
Old 03-28-2013, 06:59 AM   #38
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
It works on Air pressure. If you have the jacks down that air has dumped from the system.
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 03-28-2013, 08:06 AM   #39
adonh's Avatar
1976 31' Sovereign
Yes that was all it was, its working fine. I am still low on the learning curve about how everything works but making progress. I just found the switch for the seat vibrator yesterday. I am still tryng to figure what the audio control knobs on the right hand side of the bed are for. I think it controls 2 small black speakers over the head of the bed. It has CPS Products on the face.
Don Hardman
1976 31' Sovereign
Old 03-28-2013, 11:23 AM   #40
masseyfarm's Avatar
Images: 56
When I read your owners manual again, I see it does say your step cover is tied to the air suspension, so if it is dumped, the step would not work in this case. I find this odd, as I would have thought the step cover would be plumbed to the main chassis air, and not the suspension side.
Your owners manual does not mention a leveling system. Do you have a hydraulic level system on there Don? And do you have a book on it as it is not in the Airstream manual.
http://www.airstream.com/files/libra...9f63512971.pdf
I presume it is a chassis related item.
I see it mentions one in the original add from Colonial.
Call Colonial Airstream 1-800-265-9019 or visit www.colonialairstream.com
Options Included:
  • Chiffon Interior Decor
  • Red Metallic Exterior - Fully Body Paint
  • Window Awning Package
  • Emergency Spare Tire
  • Skylight Galley With Shade
  • Corain Flip Shelf Assembly in Galley
  • Chairs - Free Standing (2)
  • Light - Remote Search
  • Power Cord Retractor 50 Amp
  • Sofa - Ultraleather 74"
  • Power Patio Awning 19'
  • Rockguard - Rear W/Bright Stainless Insert
  • Seat - Power Passenger W/Footrest and Vibrasonics in Ultraleather
  • Vent - Fantastic Fan in Bathroom
  • Sleep Number Mattress Fantastic Fan in Bedroom
  • Delphi XM SkyFi2 Satellite Radio
  • CD Changer
  • Garmen Street Pilot 7200 Navigation System
  • Roll-Out Tray 42" (2)
  • LG 26" LCD TV - IPO Stock 20" Tube TV in Galley
  • Insignia 22" LCD TV - IPO 20" Tube Style in Bedroom
  • Winegard Roadtrip Mission - Stationary Satellite TV System
  • CB Radio
  • Custom Windshield & Side Windows (2) Sun Covers
  • Generator Exhaust Stack Kit "Geniture" Custom Wheel & Tire Sun Covers (4)
  • Jack "TV For Free" Outdoor TV Antenna
Standard Features:
CHASSIS
Freightliner XC Chassis • 330 HP Caterpillar Engine • 31,000# GVWR/41,000# GCWR • Rear Axle Ratio 4.63:1 • Air Brakes/Air Suspension w/Manual Dump Valve • Front/Rear Shocks w/Air Suspension • Raised Rail Chassis • ABS Brakes • 50 State Emissions • In Block Heater - On Board Outlet Provided • 150 Gallon Fuel Tank • Aluminum Wheels w/Radial Tires (275/70R 22.5) • 160 Amp Alternator w/Heavy Duty Isolator - Double Entrance Step - Electric Operated • 1000# HW Trailer Hitch -10,000 GVW • 2 Main Batteries • 2-40 Auxiliary Batteries w/Roll-Out Tray • Mud Flaps on Front & Rear • Emergency Start Solenoid (Momentary) • Leveling Jacks - Automatic Control • Undercoating at Select Locations • Control Stick: Signals/Cruise/Wipers/Washers/Hi-Lo Beams • Battery Disconnect-12V at Entrance Door for Coach • Pantograph Wipers w/Wet Arm & Controlled Cycle w/Extra Wide Sweep • Back-Up Warning Buzzer • Transmission Temperature Gauge • Exhaust Brake
Dave
Old 03-28-2013, 06:01 PM   #41
adonh's Avatar
1976 31' Sovereign
Yes it has the leveling system and I do have a manual on this. The PO had all of the manuals and other documents in a big loose leaf binder and some file folders.
Dave
Don Hardman
1976 31' Sovereign
Old 03-29-2013, 05:50 PM   #42
adonh's Avatar
1976 31' Sovereign
Corian Range top cover
The original Corian range top covers for the Bi-fold range top had what I first thought were chips along the front edge. But I found out that the damage was not actually chips in the Corian but burn damage. Apparently the Corian cover came in contact with a burner with a pot on it and burned as shown in the picture below. My first though was to order a replacement Corian cover from Airstream, but they no longer have the "Midnight" Corian tops. Next I thought I could repair or trim it up and eliminate the burned spots. In talking with Airstream they said these were attached with double sided tape and I thought they should come off fairly easy. But they were actually attached with epoxy. I had to pry them off in pieces. Since I could not find any 1/4" Midnight Corian I decided to make a "Butcher Block" type cover in 2 pieces and attach these to the range bi-fold top. It is 1/2 thick so it is not flush with the counter top but looks more like a cutting board sitting on the counter. I will not use it as a cutting board and stained and apply a satin finish poly and it looks pretty good when closed and open. It folds back just like the Corian one did and does not appear to be close enough of the burner to cause a problem. I have attached a couple pictures of the final results below
ID:	182065   Click image for larger version
Don Hardman
1976 31' Sovereign
