Old 06-05-2013, 10:57 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Mysterious commode smell
We have cleaned around the commode, dropped a blue pill in it, empty it on a regular basis.
The commode shuts securely as evidenced that it can retain flush water.
But from time to time, we still smell a whiff of commode "fragrance" that comes and goes. Can't seem to locate the source. Anyone else have this and can shed some light on what it was and how you solved it?
JourneytoRet is offline   Reply With Quote
Old 06-05-2013, 11:02 AM   #2
Lily&Me's Avatar
Normal , Illinois
Might be a bit of downdraft from the black tank vent?
We have the same thing on occasion. As long as there appear to be no leaks anywhere, we don't worry about it. It's a different kind of potty from the one in the stick house.
Maggie
Old 06-05-2013, 01:50 PM   #3
oh gosh doug&maggie you just reminded me. the vent on the black tank had one of those propeller-like things on it which got knocked off when a freak wind gust tore off our main awning (still to be replaced). maybe I need to run to camping world and pick up a replacement spinny-thingy???
Old 06-05-2013, 01:57 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
You might consider one of these.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-05-2013, 02:06 PM   #5
richinny's Avatar
2011 34' Classic
are any exhaust fans running when you get the smell?
Ricky
Old 06-05-2013, 05:43 PM   #6
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
If the commode is snug on its mount and the flush valve maintains its seal as evidenced by water remaining in the bowl, it doesn't seem like this is the source. The vent pipe that goes to the roof may have come loose from the tank. Another possible source is the GW tank. Bits of food from washing dishes gets down there and the GW tank can get funky too. If not used regularly, the water in the p trap under the sink may evaporate enough to let GW tank odors come in through the sink drain. Under many sinks there is an air valve with a 1-way vent that assists the draining action of the sinks. If that flap gets weak, odors can back up through it also. These odors are often noticed if the wind is just right. Try pouring some liquid or powder deodorizer down a sink to see if that helps.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-05-2013, 05:58 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If there is improperly sealed between roof and pipe there will be stink leak
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 06-05-2013, 06:37 PM   #8
2013 27' FB International
Beaufort , South Carolina
Black Ops, Funky smell
We have a 2011 International which we have taken on several trips over the last two years and had no black tank odor issues. Suddenly, last month while in Florida I could sense the "aroma". We were active in our travels and moved a lot. One thing I noticed was that the odor was only present while we were setting up after pulling. It seemed to fade after we were stationary for a while. The bowl seal holds water so that isn't it. My next research will probably be the vent pipe. I am interested to know what anyone else may have figured out.
Another Road is offline   Reply With Quote
Old 06-05-2013, 07:37 PM   #9
1988 32' Excella
Robbinsville , New Jersey
You didn't mention the shower drain, some people don't use the shower in their trailer or at least not the first day of a trip.
