Old 08-09-2013, 10:17 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Mysterious Brownouts?!
Has anyone had this happen? We've owned the clipper for 4 months and now have this weird problem:
The a/c, microwave, convection oven, anything that is powered by the campground will go out. Then about 10 seconds later, everything comes back on.
Now, if I trip the breaker at the campground, I of course lose the things mentioned above. After resetting the breaker, I have to reset the clocks.
But when this brownout happens, I lose power, but I don't lose any clocks. If I unplug the VCR for the same amount of time, 10 seconds, and plug it back in, I DO lose the clock.
Anyone have any ideas?
JourneytoRet is offline   Reply With Quote
Old 08-09-2013, 10:29 AM   #2
1974 Argosy 20
Kooskia , Idaho
Several things come to mind. One is that you have a transfer switch issue. There is a delay built into them and could cause the problem in just the right situation.
Another possibility is that you have a loose connection somewhere in your input panel, and when loaded it is heating up and causing the disconnect but still allowing a very small amount of power through, enough to run the clocks.
The problem is kind of hard to diagnose remotely, but I bet you will find the issue in either the transfer switch or the panel. I am of course assuming your cord and plug set is in good condition, and the outlet you are plugged into is also good. They also could cause the issue with heat and load.
Old 08-09-2013, 10:57 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Undock AS
Open breaker box
Test there is no power
Tighten all connections in box
Check where power cord comes in there will be junction box before the breaker box usually. Look inside to be sure all good there.
If all good maybe prob with power cord plug end. Is it new? Etc.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2013, 11:05 AM   #4
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
I'd also check the campground power. Some campgrounds have old/bad power that varies widely that we found out first hand. Use meter at power source to see if power is stable.
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 08-09-2013, 01:50 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Is it only at one campground?
If it is ask your neighbors if they are having problems to.
Old 08-13-2013, 12:15 PM   #6
love the pic!
Old 08-26-2013, 10:04 AM   #7
ok, opened the box, after undocking, and tightened all screws. found a few where I could turn the screw maybe 1/16th" of a rotation, closed the box and connected to the campground. voila! everything is peachy keen, thanks!
The mysterious disappearance of wannabe fulltimers Jammer Full-Timing 154 04-24-2014 03:33 PM
Mysterious Electronics - 2007 19' Bambi randf Electrical - Systems, Generators, Batteries & Solar 15 05-31-2012 05:11 AM
