Old 09-04-2016, 11:23 AM   #1
SteveH's Avatar
Common Sense , Texas
Mirror Back Splash Removal?
I remember reading on here that someone had removed the mirrors from the kitchen backsplash area, and I've searched for it with no luck.
If anyone reading this has done it, please let me know the procedure you used because I don't like the idea of breaking all the glass mirrors and then trying to sweep up all the glass.
Regards,
Steve
Old 09-05-2016, 09:50 AM   #2
SteveH's Avatar
Anyone?
Regards,
Steve
Old 09-05-2016, 10:25 AM   #3
Streamin'
BarnacleBill's Avatar
1995 30' Cutter Bus LE
Madison , New Mexico
I don't have any experience with this but just wanted to let you know someone is reading your post. Heat?
BarnacleBill is offline   Reply With Quote
Old 09-11-2016, 07:24 AM   #4
SteveH's Avatar
Again, anyone?
Regards,
Steve
Old 09-11-2016, 08:06 AM   #5
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Tape the mirror up and tape it to walk. Then use a heat gun all over till it pops away from wall.
I ll also search a bit.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-17-2018, 08:30 PM   #6
2000 36' Land Yacht XC Diesel
Conroe , Texas
Did you remove the mirrors in the kitchen area ?
I just purchased a 2000 360xc dp a few weeks ago. Wifes first idea was to remove them.
Maybe apply new one over it?
Let me know.
Lford is offline   Reply With Quote
Old 12-26-2019, 05:15 PM   #7
1999 35' XL 355 w/slide
lakeland , Florida
I just removed the mirrors on our 355xl. They are applied wit strips of double stick tape. I started on the end and used what I had, a framing square and slid if behind the mirror with enough force to separate the tape. I had minimal breakage, some came off in full pieces. The microwave had to be removed. We went back with peel anx stick backsplash. Less weight and more modern look. There was no damage done to the wall and cleanng off the remaining tape wasn't very difficult at all. We are very happy with the end result. Click image for larger version
ID:	358238Click image for larger version
ID:	358239Click image for larger version
cdpalm is offline   Reply With Quote
Old 12-27-2019, 08:32 AM   #8
Conroe , Texas
Hood to hear how you did it. I have done the bathroom backsplash and was wanting to do the kitchen area. Woner about the gap since the stick on tiles I have a not as thick as the glass. Any problem?
Old 12-28-2019, 07:41 AM   #9
lakeland , Florida
The beveled mirror is thicker than the tile but i ran the tile into the groove in the corian splash thinking i would make up the difference with clear caulk but I never did it because it is barely noticeable. We've been replacing carpet with vinyl plank flooring and wallpapering the walls and putting a booth and new furniture and window treatments. Once we make our first trip since the renovations I'll know more how it all works out but getting rid of the mirrors definitely modernzed our 1999 Airstream. I'm sure there is a better tool than a framing square but it worked out ok minus a few blisters, lol. Good luck with your project. I think you'll be pleased with the results.
Old 12-29-2019, 07:15 AM   #10
Conroe , Texas
Will try it this winter.
We already replace the carpet, upholstery. Shades, old tv. and
Window treatment.
Old 01-06-2020, 09:07 PM   #11
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
How did you replace the carpet under the slide.
Any problems with getting thicknesses the same
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
Old 01-07-2020, 04:25 AM   #12
lakeland , Florida
The slide worked out very good, i just started on that side and butted the planks up to the roller blocks mounted on the floor. I did have to make poster paper templates which made cutting the plywood subfloor and planks a lot easier to fit. I put the plywood down to get the height the same when butting up to the tile in the kitchen area. There was no way to remove the brass trim on the tile without destroying the tile so that was a little tricky but worked out well. It was the best part of our renovation because it expised some leaks we were having around the slde and windows. If you tackle it it really will be a fun project and well worth the results. Its a lot easier to keep clean. Good luck!!!Click image for larger version
ID:	358811Click image for larger version
ID:	358812Click image for larger version
ID:	358813Click image for larger version
ID:	358814Click image for larger version
Old 01-07-2020, 04:33 AM   #13
lakeland , Florida
I did treat the plywood with sealer prior to putting down he planks just as a precaution. Then came the wallpaper and new furniture. We love the end result.Click image for larger version
ID:	358816Click image for larger version
ID:	358817Click image for larger version
ID:	358818Click image for larger version
Old 02-20-2021, 08:29 AM   #14
baldwinh's Avatar
2002 36' Land Yacht XC Diesel 300 hp w/2slides
LIVINGSTON , TX
365XC Interior remodel
Here's the link to our blog post on the interior remodel of our 365XC
https://herbnkathy.com/2017/12/12/in...eam-motorhome/
We also used a long thin putty knife to get behind each mirror panel and "tear" the adhesive tape to get it off the wall. We didn't remove the mirrors at the kitchen because they are actually installed behind the countertop .. we would need to remove the counter
Although in this video we recovered the window boxes, we have since replaced those boxes altogether with solid oak boxes made by local Amish
baldwinh is offline   Reply With Quote
Aluminum Wall Back-splash and Range-hood ALUMINUMINUM Interior Restoration Forum 24 01-09-2023 07:19 PM
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
Mosaic tile back splash tkasten General Interior Topics 12 01-01-2012 02:14 PM
Splash of glitz and a skosh of fun wheel interested General Interior Topics 42 03-23-2010 05:08 AM
back splash walls in aluminum; CCD owners please help SmokelessJoe Cabinets, Counter Tops & Furnishings 5 05-09-2007 10:43 AM
