Old 12-27-2015, 09:11 AM   #1
2006 39' A-Series
Prescott , Arizona
Location of sub panel
I have a MY2000 390XL. The 110v wiring diagram says there is a 30amp sub panel (in addition to the main 110v panel at the foot of the bed). But I cannot locate this 30amp sub panel. And suggestions? Thanks and Happy New Year!
jwitwer is offline   Reply With Quote
Old 12-27-2015, 09:18 AM   #2
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
you probably do not have one. My diagram shows the same thing, even labels it as such in the breaker box. Are you having problems or just curious?
Greg
Roadtoaster is offline   Reply With Quote
Old 12-27-2015, 09:52 AM   #3
2006 39' A-Series
Prescott , Arizona
Greg,
Thanks for the reply. I popped a circuit breaker (space heater and high power espresso maker at the same time), so I lost the GFI circuit that supplies the kitchen and bath plug. I thought it might just be that the GFI popped, but that does not seem to be the case. So I was thinking it might be a circuit breaker in this mysterious "30 am sub panel".
Jeff
Old 12-27-2015, 09:55 AM   #4
Figured that might be the problem as it happened to me. Check your inverter. If it's like mine, there are 2 circuit breakers on the right side, kind of look like light switches. Hard to see and get to but I will bet that is what has tripped.
Greg
Old 12-27-2015, 10:05 AM   #5
2006 39' A-Series
Prescott , Arizona
Wow!! That did it. Thanks. Take a break. You did your good deed for the day!
Jeff
Old 12-27-2015, 10:07 AM   #6
Glad it worked, now you can drink that fancy coffee!
Greg
Old 12-29-2015, 10:01 AM   #7
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Now that you have discovered those two breakers, trip one at a time and see which outlets are supplied from which breaker. If they wired it up in a sensible way, you might be able to keep bigger appliances off the same circuit. Bet all outlets on the kitchen bench including the microwave are on the same circuit
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
Honeycomb Aluminum Panel As Sub Floor, the adventure... Rivka Repairing/Replacing Floor &/or Frame 37 12-25-2015 03:25 PM
Mounting 120v sub panel box PA BAMBI II Electrical - Systems, Generators, Batteries & Solar 1 05-20-2015 03:45 PM
Alluminum panel below sub floor JLGT5107 Repairing/Replacing Floor &/or Frame 1 09-04-2010 11:49 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
