11-25-2015, 06:37 AM
Common Sense
Location of Solar Controller?
Does anyone know the location of the solar controller in my '05 396XL motorhome? I think it's not only not working, but may even have become a draw on the batteries.
I did do a search, but when I do searches on this forum I get so many hits it would take days to read thru them all. I've found it worthless.
Regards,
Steve
11-30-2015, 08:39 AM
Common Sense
NO ONE knows where the solar controller is physically located?
Regards,
Steve
11-30-2015, 10:04 AM
2008 27' International FB
Venice
Think of calling Airstream in Jackson Center?
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
11-30-2015, 10:09 AM
Common Sense
Actually I have not because of the response I got the last time I called them about a part for the MH.
Regards,
Steve
11-30-2015, 01:50 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
steve, as a total guess i'd start looking near the 12v distribution panel.
Ricky
11-30-2015, 02:22 PM
Common Sense
I called Airstream and they got back to me after a few hours and said it's behind the indicator panel, or part of that panel, which is in the big road side slide.
They also told me it's only 10 watts, so I wonder why they even put it in there.
As soon as it's sunny here, I will check it out, but it's not close to the 12v distribution panel.
Regards,
Steve
12-01-2015, 01:16 AM
2000 36' Land Yacht XC Diesel
Fresno
The stock solar panel is only a chassis battery keeper....basically it does its best to keep your chassis battery from dying (say in case you forget to hit the battery disconnect...or your housekeeper always forgets when she's cleaning it up after a trip)...but, as you mentioned, it IS only 10 watts...just enough for 2 chassis batteries. My outside inverter is in my first cabinet behind the entrance door, with my coach batteries. If you want real solar power you're going to have to upgrade your existing system...and possibly even your inverter.
Don't get me wrong I will never pretend to even look like I can understand what the difference between pure sine or sine or blah blah inverters are, but, whatever the best one is, I have it, and boy it wasn't cheap. 2000w pure sine inverter, coupled to 1000w of panels on the roof and a 200w portable. I started off with Renology...but I realized the cables that came with them were crap so replaced all those, I still use their controller, even though I still don't know how to use it properly...literally, no words, just emojis...lord have mercy. Also, I'm pretty sure even in '06 the interior switch for the inverter should be just behind the kitchen before the bathroom. That allows me to turn my inverter on and off without having to exit the coach. Hope that helps.
12-01-2015, 07:06 AM
Common Sense
Thanks, that gives me a better understanding of the system because I thought it was for the coach batteries, and did not know it was only for the chassis batteries.
The thing that I've found difficult moving from a trailer to a motorhome is the differences in all the systems. And the book is yet another confusing subject.
It has been a rather steep learning curve, and based on this information, the solar system has virtually nothing to do with the problem I'm experiencing, and that is rapid discharge of the coach batteries.
Regards,
Steve
12-01-2015, 08:46 AM
2005 39' Skydeck
Alameda
I am shopping for a battery monitor for this exact issue. I have had my NEW batteries die completely two times so far and I have only owned the coach for a few months. Initially I hooked a 50 watt solar panel to it via the 12v ports and yet the battery died. I will wire it directly but I have not done that yet. After removing the solar and turning everything off I still had the batteries die completely in just a few weeks. Now I try to remember to power off the coach when I leave so the stereo and the propane detectors turn off, but I cannot imagine why the batteries die so quickly when the circuit is left on. Wish there was a way for the batteries to turn themselves off when the voltage gets too low.
I have purchased a battery shunt display that I will install to see how much battery I am loosing, but I am currently (pun not intended) shopping for a battery monitor or an automatic generator start or a solar charge system that will keep my batteries happy, as they were not cheap.
My inverter/charger was replaced before I got the RV with the Xantrex 458, so the old solutions of the Xantrex Link 1000/2000 battery monitors are not listed as working with my inverter. There is the Xantrex 84-2064-00 Auto Gen Start that is listed as working with my inverter but it starts based on battery voltage of 11.2v. What if I have a crappy solar panel hooked up? Will it keep the generator from starting during the day, despite being underpowered? Wish I could find an expert on these systems...
-Randy
12-03-2015, 08:33 AM
Fresno
Unless you have already, I can say this without even knowing nor it mattering what year your new (or new to you) coach is....REPLACE THE COACH BATTERIES! Both my rigs have been single PO's....but, I'm certain they fudged the date on the battery replacement, or, honestly, just didn't know or were lied to by a dealer...either way, getting new batteries coach wide solved every electrical problem I had been having up till then. It may set you back a few hundred, but it's worth every penny, by far. Battery chargers & keepers are great, but only if they're charging/keeping batteries worth charging/keeping.
12-04-2015, 10:52 AM
2005 39' Skydeck
Alameda
Yeah, new as of May, when I bought the RV. Learned my lesson on my first RV purchase, came dead from the dealer as it had been sitting on the lot. I then promptly killed the new battery I bought thru ignorance. So now I am very concerned about keeping batteries charged, ESPECIALLY new batteries like these.
-Randy
12-04-2015, 11:59 AM
Common Sense
My coach batteries (two very big 12V) are new, but I don't know the age of the chassis batteries.
Regards,
Steve
12-04-2015, 12:44 PM
2004 28' Classic
2003 25' Safari
Florence
, Oregon
On most coaches have a propane detector is hard wired to the batteries, Even if the disconnect is tripped the propane detector will pull from the batteries until completely dead. Some safety requirement.
If you can remove the batteries, store in cool place with a battery minder. Keeps the batteries charged and free from freezing. Or try and put a minder on the battery with external power. In a little over a couple of weeks in cold weather the propane detector will kill all the batteries.
12-04-2015, 01:15 PM
Naples
[QUOTE=israndy;1717824]I am shopping for a battery monitor for this exact issue. I have had my NEW batteries die completely two times so far and I have only owned the coach for a few months. Initially I hooked a 50 watt solar panel to it via the 12v ports and yet the battery died. I will wire it directly but I have not done that yet. After removing the solar and turning everything off I still had the batteries die completely in just a few weeks. Now I try to remember to power off the coach when I leave so the stereo and the propane detectors turn off, but I cannot imagine why the batteries die so quickly when the circuit is left on. Wish there was a way for the batteries to turn themselves off when the voltage gets too low.
Randy,
Any charge going to your batteries will throw off any AGS system. For a battery monitor in your case, I would use a TriMetric. What size shunt do you have?
Too bag you don't have a Magnum, as both the AGS and battery monitor can be seamlessly installed and read thru a single ME-RC remote.
How big is the solar and what type of solar controller do you have??
Lew Farber
RVIA Certified Master Technician
ABYC Certified Master Marine Electrician (pending)
*AM Solar Authorized Installation Center
**Lifeline Batteries***Magnum Inverters
*Member, Aqua-Hot National Rally Service Team
Master Tech Energy Systems Inc.
278 Capri Blvd.
Naples, FL 34113
2149 W. Cascade Ave. Suite 106A-214
Hood River, OR 97031
541-490-6357
866-490-6801 (fax)
lewster
12-05-2015, 12:30 AM
Fresno
I have to second swapping out your inverter for a Magnum....I can't lie I basically copied a lot of my parents Prevost's features....on a budget.
12-05-2015, 04:31 PM
2005 39' Skydeck
Alameda
Yeah, the Xantrex 458 is new since the RV was built, no idea what year, but they wired in a display panel in the bath as it was a smidge too big to fit where the other panels go. But the Xantrex AGS panel should fit were the original Xantrex inverter's panel was, so I'll stay with Xantrex. I hear good things about Magnum, but have not heard anything about them integrating with a solar controller.
Lewster, I was looking at the Link 1000 from Xantrex as that show the inverter charger and the battery monitor on the same panel too. Just not available anymore. Seems smart to have the battery monitor tell the battery charger what to do. Even if I got the TriMetric it won't help the solar/AGS. I think I will simply install the AGS and see what the solar does over time... Perhaps if the batteries are getting low and the sun is going down, the generator will kick in
-Randy
12-05-2015, 08:00 PM
Naples
-Randy
The battery monitors won't tell the chargers how to respond, unless it is fully integrated unit like the Blue Sky with the iPN-PRO remote. They are a fully integrated solar charge controller along with full battery monitor functions.
Magnum's BMK will not control the charger section of the inverter either, as the inverter is smart enough to perform that function seamlessly thru it's own voltage sense.
Your AGS will not function while you have a second charging source like solar putting voltage into your batteries. The AGS will 'see' this voltage and consider it as a fully charged battery. It will only start the Generator when your batteries are at the pre-set level. You have to be careful about setting that lower level, as using the inverter under large loads like a microwave will produce temporary transient voltage levels approaching 11.0 VDC and possibly less for a lead acid based battery bank.
Lithiums will not show this type of voltage drop, but they will also not work with AGS systems because of that feature.
lewster
12-22-2015, 11:23 AM
Common Sense
Well, I finally got around to removing the panel where Airstream said the controller was, and it isn't.
So much for checking with the manufacturer......
Regards,
Steve
