Old 12-05-2015, 12:30 AM   #15
2000 36' Land Yacht XC Diesel
Fresno , California
I have to second swapping out your inverter for a Magnum....I can't lie I basically copied a lot of my parents Prevost's features....on a budget.
LucasS is offline   Reply With Quote
Old 12-05-2015, 04:31 PM   #16
israndy's Avatar
2005 39' Skydeck
Alameda , California
Yeah, the Xantrex 458 is new since the RV was built, no idea what year, but they wired in a display panel in the bath as it was a smidge too big to fit where the other panels go. But the Xantrex AGS panel should fit were the original Xantrex inverter's panel was, so I'll stay with Xantrex. I hear good things about Magnum, but have not heard anything about them integrating with a solar controller.
Lewster, I was looking at the Link 1000 from Xantrex as that show the inverter charger and the battery monitor on the same panel too. Just not available anymore. Seems smart to have the battery monitor tell the battery charger what to do. Even if I got the TriMetric it won't help the solar/AGS. I think I will simply install the AGS and see what the solar does over time... Perhaps if the batteries are getting low and the sun is going down, the generator will kick in
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 12-05-2015, 08:00 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
-Randy
The battery monitors won't tell the chargers how to respond, unless it is fully integrated unit like the Blue Sky with the iPN-PRO remote. They are a fully integrated solar charge controller along with full battery monitor functions.
Magnum's BMK will not control the charger section of the inverter either, as the inverter is smart enough to perform that function seamlessly thru it's own voltage sense.
Your AGS will not function while you have a second charging source like solar putting voltage into your batteries. The AGS will 'see' this voltage and consider it as a fully charged battery. It will only start the Generator when your batteries are at the pre-set level. You have to be careful about setting that lower level, as using the inverter under large loads like a microwave will produce temporary transient voltage levels approaching 11.0 VDC and possibly less for a lead acid based battery bank.
Lithiums will not show this type of voltage drop, but they will also not work with AGS systems because of that feature.
Old 12-22-2015, 11:23 AM   #18
SteveH's Avatar
Common Sense , Texas
Originally Posted by SteveH View Post
I called Airstream and they got back to me after a few hours and said it's behind the indicator panel, or part of that panel, which is in the big road side slide.
Well, I finally got around to removing the panel where Airstream said the controller was, and it isn't.
So much for checking with the manufacturer......
Regards,
Steve
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Brake controller location TomW Brakes & Brake Controllers 4 08-30-2004 01:04 PM
