Old 05-20-2012, 06:04 PM   #1
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
How do you pour bleach into freshwater tank ?
Probably a silly question..we've owned this MH since last fall, and had the tanks sanitized by our RV repair shop in the winter. We're getting ready to go on a trip and wanted to sanitize the tank again since its been six months, and we can't figure out how to pour the sanitizing solution into the freshwater tank!
We have a connection for hose to fill the tank, but, it's impossible to pour the diluted mixture into the tank...how are you supposed to do that??
David
dgmelp is offline   Reply With Quote
Old 05-20-2012, 06:08 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
I put the bleach in a large measuring cup and use a funnel to pour it in. Then fill with water.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 05-20-2012, 06:13 PM   #3
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
We have the funnel...and we mixed the bleach...now, how do you get the water in the funnel into the freshwater tank? The only inlet I have is a female hose connection in the compartment with the valves in my MH. Is there another way to pour this in?
Old 05-20-2012, 06:21 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I use an old automatic transmission fluid funnel, try nappa and ask an for an ATF funnel.
The long nose stays put.
ooop's MH, never mind.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-20-2012, 06:29 PM   #5
dznf0g's Avatar
Oswego , Illinois
I don't measure too accurately as I flush thoroughly....probably somewhere between a pint and a quart. I got a trans funnel which fits nicely.
-Rich-
Old 05-20-2012, 06:37 PM   #6
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
I should have been more specific....the fresh water female connection has a metal filter screen imbedded in the inlet...and I can't put a funnel hose through that...and I can't figure out how to remove the screen. Any thoughts?
Old 05-20-2012, 06:38 PM   #7
dznf0g's Avatar
Oswego , Illinois
Is it threaded? How about a picture?
-Rich-
Old 05-20-2012, 06:47 PM   #8
Home Depot sells these, short length of hose connected to your funnel.
PFC
"Tahawus"
RLC
John Prine
Old 05-20-2012, 07:35 PM   #9
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
Picture of water inlet
Hope these pics give you some idea of my dilemna.
Old 05-20-2012, 07:36 PM   #10
dznf0g's Avatar
Oswego , Illinois
OK, that appears to be your city water inlet....not your tank fill port, unless you setup is unlike anything I have ever seen.
-Rich-
Old 05-20-2012, 09:00 PM   #11
dgmelp's Avatar
1996 30' Cutter Bus
El Paso , Texas
And that is my dilemma....I can't find the other inlet anywhere on this motorhome....and this inlet does fill the water tank. Above the inlet is a valve you open if you want the water to go directly into the tank from this one inlet instead of just pressurizing your water system.
Anybody else have a motorhome with something similar?
Old 05-20-2012, 09:04 PM   #12
dznf0g's Avatar
Oswego , Illinois
Really??? If that's the case, get a MALE hose end with the barb (opposite from what Bob shows above). Then get a trans funnel, with a hose attached, again like Bob shows, further upthread. I suspect that when your valve is in the tank fill position, the Clorox will flow in. I believe, when the valve is in the "non-tank fill" position, a pressure regulator and check valve will prevent the free gravity flow of the Clorox.
-Rich-
Old 05-20-2012, 09:31 PM   #13
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
This is my fresh water fill on the Clipper located at the lower edge of picture.
Dave
Old 05-21-2012, 06:23 AM   #14
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Actually, removing the screen shouldn't be difficult. If it's like the ones I installed on my Interstate, the screen is actually attached to the rubber gasket. Use a metal dental pick to grab the rubber gasket around the edge, and pull. Slowly. It should pop right out, gasket, screen, and all. I keep a dental pick in my toolkit, just so I don't get it mixed up with the one I use on my teeth.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Freshwater Tank drain crazeevw Classic Motorhomes 9 10-28-2011 08:16 PM
Chlorine Alternative for Freshwater Tank Hummingbird Fresh Water Systems 16 07-06-2011 08:25 PM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
