Old 11-29-2013, 02:50 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
We have camped in colder weather than this- with less warming devices-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-29-2013, 04:42 AM   #16
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
In the 20's overnight - furnace alone did the job - stayed warm - furnace runs a lot but quiet - also running a small fan to help circulate air and help create even noise
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 11-29-2013, 06:34 AM   #17
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
We always use the furnace when the temp gets into the low 40ies or below. I find it more efficient and quieter then the HP.
urnmor is offline   Reply With Quote
Old 11-29-2013, 06:50 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up When power available....
Heat pump down to about 35*....what!!! I can't hear you. (A very good excuse should the need arise.)
Pelonis Disc Heater & Furnace below 35*. Furnace for the quick warm-up and the Pelonis to help maintain.
Plus on a day like today with 5" of snow @ 35* I'll use the Pelonis to help remove interior condensation. It will usually bring the temp up to 50*+ after several hours.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 12-01-2013, 10:57 AM   #19
2004 30' Classic
Peterborough , Ontario
We live in Ontario Canada our spring and fall trips have over night temps down to 20 degrees and we use the furnace for over night even both of them. The electric may tack the chill off during the day.
My thoughts
Russ
dirtturner is offline   Reply With Quote
Old 12-01-2013, 07:30 PM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
In the wake of our first trip and nights in the 20's I will be try a small ceramic room heater for reasons stated here - furnace would run and quickly warm up but too warm in some parts during heat up and prior to kicking on a bit too cold in areas - perhaps the small room heater in select areas...but the furnace alone did pretty good -
Wish I could figure out how to **** off heat vent for the front (main) bedroom
Old 12-01-2013, 09:58 PM   #21
Thumbs up
The few times we've needed more warmth in the bedroom, I've just covered these two front outlets with packaging tape. Fold an inch of the tape end for a pull tab to remove.
Stream Happy.....
PFC
"Tahawus"
RLC
John Prine
Old 12-01-2013, 10:51 PM   #22
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
When needing heat in cold weather...
We quickly found that the furnace was noisy, intermittent, and the fan used way too much battery power when boondocking.
When we had an electrical hookup, we found that a small, cubic heater, such as this, worked well and was quiet.
We now prefer the Vornado AVH2 Vortex Electric Heater for even, quiet heat when we have an electrical hookup.
When we are doing non-hookup camping and expecting cold temperatures, we bring along Mr. Heater Portable Buddy.
See how we use Mr. Heater Portable Buddy: "Snug as a bug in a Safari".
SilverGate is offline   Reply With Quote
Old 12-01-2013, 11:16 PM   #23
mefly2's Avatar
2015 25' FB Eddie Bauer
IIRC the suggestion is to NOT use the heat pump at temps under 40 degrees. Above that, we like to use the heat pump when connected to pedestal (saves propane)... at least to warm the cabin a bit before starting the furnace.
Old 02-18-2015, 09:01 AM   #24
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Originally Posted by PharmGeek View Post
I'm headin to monte sano state park this weekend - will be running the furnace to keep things toasty - will likely put fresh water in fresh water tank in case campground pipe freezes and unhook city water at night as temps to drop a bit below 30 degrees
Brrr - Disney movies with the fam at night
I want to try a ceramic heater at some point but my wife doesn't want to add something "to get in the way - and doesn't this thing already have a heater"
[sounds like my wife!]
JourneytoRet is offline   Reply With Quote
Old 02-19-2015, 07:09 AM   #25
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
But mine changed her mind about heating with a ceramic when she heard the noise coming out of the furnace(located within a foot her choice spot on the couch). Second ceramic heater we tried was actually almost silent, and it's footprint was less than a foot square, no kids or pets to kick it and placed right it can take the chill off without being in the way.
Old 02-19-2015, 08:02 AM   #26
dznf0g's Avatar
Oswego , Illinois
Stream Happy.....
Bob, careful. Don't reduce the square inches of flow opening that the furnace mfr recommends. They can overheat.
I installed a close-able round register in ONE of the lounge openings AND added a second duct run to the bedroom. That keeps the same airflow volume recommended in the furnace manual.
-Rich-
Old 02-20-2015, 03:03 PM   #27
urnmor's Avatar
Berlin , Maryland
We prefer the furnace as it is quiter then the HP.
Old 02-20-2015, 04:43 PM   #28
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Dry camped with my nephew last night. AM temps at 19F, stayed warm with small milk house heater and electric blanket for me. I have used the strip heater in mine but the fan is a bit noisy. It would have worked fine to take the edge of the low temps, but the little heater works so much "nicer".
Clayton
NavyCorpsman is offline   Reply With Quote
