Old 11-11-2014, 06:21 PM   #1
1999 35' XL 355 w/slide
Arlington , Tennessee
Ground wire??
When I removed the heater fan motor to replace it, I found a large (about #10 wire or so) white wire with a large (1/4 inch hole) ring on the end of it hanging down behind the glove box, not connected to anything. It appears to show about 0.3 ohm resistance between it and the ground to the fan motor, so I presume it is a ground wire for something. Does anyone have any idea where it should be connected? I see no obvious place under there. Is it safe to assume all white wires are grounds? That seemed to be true of the Coachmen I used to own.
tebreuer is offline   Reply With Quote
Old 11-15-2014, 07:43 PM   #2
Can't figure out where it goes so I left it hanging. In the process I found out my Ford chassis Airstream has a cheap General Motors heater blower. interesting.
Ground wire getting hot????? 86Scotty Batteries, Univolts, Converters & Inverters 45 02-09-2014 04:09 PM
Ground Wire Help Please basecmp Electrical - Systems, Generators, Batteries & Solar 7 05-05-2008 07:53 AM
1960 Traveler lose ground wire from hitch JimHoek General Repair Forum 7 09-21-2007 06:54 PM
Where to put ground wire? ChicknKathy Batteries, Univolts, Converters & Inverters 2 05-17-2007 01:51 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
