Old 06-11-2013, 05:59 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Grab Bar entrance door
My Grab bar at the entrance door to the coach has the clear acrylic type handle attached to a chrome base at both ends. I have seen these as "lighted" grab bars on other coaches so I decided to take a look to see if may my bulb was burnt our since I had not seen this one light up when the porch light is on. The chrome base on each end has a cover that can be removed and you can see the screws that attach each end to the coach. But no light or wires. It looks like this could be lighted but for some reason was not. Here is a picture of the base with the cover off and it looks like a bulb similar to the one shown in the link below might fit and could be wired to the porch lite switch.
Any thoughts. Thanks
LED Light for Illumagrips 86430 LED Assem | eBay
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 08-08-2013, 10:12 PM   #2
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Don, if you check out the post in the Land Yacht/Legacy section 2/24/13 under the topic, I need to get a handle on a few things, post #11,12,and 13 I show some pictures of my handle that I installed a light in. My acrylic handle is shaped differently than yours, but it looks like yours would have enough room to do the same. I tied mine into the keyless entry system, I didn't use a LED light, just an automotive cornering lamp light bulb. I was able to make the connection under the sink. I'm happy with the results.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
