Old 09-28-2015, 07:03 PM   #1
israndy's Avatar
2005 39' Skydeck
Alameda , California
Fulton Door Lock Key Blanks?
Trying to get a spare key for the entry door. Cannot find them online after starting with both the Lowes where I park the RV and then the good locksmith here in Alameda.
When I was first playing with the door lock I was unable to turn the red knob, since it was snapped off I assumed the lock failed before I bought it. Tried it again this weekend and it turns. I had planned on replacing the lock but turns out it's WAY different than most locks on the market. The post is on the door frame, not the door like most aftermarket locks. If it works all I really need is a key blank. Oh, and a red lever...
Any thoughts?
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 09-28-2015, 09:35 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Check another full service locksmith. I found replacement keys for all my locks at one. Even after several here said I could only get them from Airstream.
MICHAEL
Old 09-28-2015, 11:07 PM   #3
1974 Argosy 20
Kooskia , Idaho
My excellent old line locksmith, who has been around forever, still tells me he cannot get the right blanks for my 2014 FC 20. I got them from my AS dealer and the locksmith made the extra keys from them. Seems strange as they are a true quality locksmith, and have done some interesting sleuthing and finding the right blank for me on some pretty strange locks. One Airstream I had they found used a 1956 Ford key blank which left everyone shaking their heads.
Glad you found them at a locksmith AWCHIEF, cherish them.
Old 10-06-2015, 08:03 PM   #4
israndy's Avatar
2005 39' Skydeck
I spoke to Airstream and they do have blanks on their store site, but none looked like the key I have. I did order their deadbolt key blank just to see if it's at least the right key for my missing deadbolt key.
So I went to the super high end security place near me and got them to inspect my key. They looked everywhere and came to the conclusion that they cabinet key the first locksmith made for me was the correct blank. They figured it was just a bad copy. They didn't charge me just in case I had the same experience I did with the first copy.
I'll try it this weekend. Cannot wait to have a second key in case of losing this one.
-Randy
Old 10-07-2015, 09:38 AM   #5
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Check EBay. I was able to purchase mine pre- cut.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is online now   Reply With Quote
Old 01-13-2016, 12:28 PM   #6
israndy's Avatar
2005 39' Skydeck
Finally got someone at TriMark
I sent them a picture of the lock and was told the model was an old 030-1000. No longer supported. I asked 4 time for a key blank and kept being told that it was not possible as there are thousands of keys and we need the number on the key to replace it. Finally asked to explain it to me like to a two year old and got her to tell me that they DO sell blanks and the blank for the key was the KS200, they go for $2 a pop. So they are sending me them.
My mechanic in the mean time had success in the same time frame, managed to take my key and make a copy onto a KS300 that he had access to. Cannot wait to have them both in the same room, but at least I finally have a spare key so my mechanic and I can both get in the RV whenever we want. Gonna have him start working on sealing the roof, take off the SkyRim or whatever those 4 fiberglass pieces are called and make it water tight. FUN!
-Randy
Old 01-13-2016, 06:19 PM   #7
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Make sure to take pictures how they come off as I have to do the same soon.
I cleaned my wall covering with a steam cleaner they look like new.
Peter
PSchw is offline   Reply With Quote
Old 02-08-2016, 10:20 AM   #8
israndy's Avatar
2005 39' Skydeck
Got a working key!!
Looks like my issue with finding a key to duplicate the door key that came with the RV was due to someone making the copy onto a completely different key type.
Square head on the new key
The Fulton key worked perfectly, but at all the locksmiths I went to the only key that was close was the Y13 cabinet key, although one mentioned a key C02 that was not found anywhere anymore. The KS200 key blanks I got from TriMark looked SO different that the first locksmith didn't wanna cut the keys.
I took the blanks to the RV and confirmed that they work on the door and after cutting I FINALLY have a backup key I can give the mechanic. He did cut his own from a KS300 that ~works~ in the door, but... it's rather tough to get to turn, almost like the Y13s that people kept cutting for me. The KS200 works as well as the Fulton that came with the RV.
Now I need to get my wireless FOB working. Replaced the battery, but it is unresponsive, perhaps I have a blown fuse. My step isn't working either, got to get a good fuse puller.
Old 02-08-2016, 10:44 AM   #9
israndy's Avatar
2005 39' Skydeck
Peter
The mechanic is talking about taking the top off the parameter. The piece is extruded aluminum. Lots of rivets to put back. He showed me that there are a LOT of missing rivets already. He thinks it will take 6 hours to remove & replace the two fiberglas caps and the parameter cap and long fiberglass sides. They think it will only take an additional 6 hours to do the same to all the furniture. They are writing me a quote for doing this and then removing the old sealant and spraying the fiberglass roof with truck bed liner. Not sure what I want to do.
What is a steam cleaner? My wife has a rug vac that you put hot water with carpet cleaning solution in one tank and then it sprays the solution on and vacuums it off. I would love to get the water stains off my walls. Once the mold is out I don't want to have to replace my sidewall covers if it's possible to get them clean. Is this something you rented or is it just what my wife already has?
-Randy
Old 02-08-2016, 10:08 PM   #10
PSchw's Avatar
Livingston , Texas
I rented the steam cleaner which is actually a carpet cleaner with a smaller furniture attachment from Walmart.
Like I said worked great.
Peter
Old 02-20-2016, 10:44 PM   #11
israndy's Avatar
2005 39' Skydeck
-Randy
OK, I got the red lever installed today, it's like the lock is brand new without having to purchase a new lock or change out the door. If you have to install this it is super simple. It comes with a ring that holds the knob in place. Once the lock face is removed with a torx driver you drop the ring on the back side of the face. I held it on my finger tip while putting the face back. Screwed it down and pushed the knob in. So easy. I would post a picture, but it looks exactly like yours does.
-Randy
can I order key blanks? macofpei Doors & Locks 10 11-20-2008 10:03 AM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
key blanks needed Judy Barde Doors & Locks 13 06-19-2008 11:24 PM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
Key Blanks ZoominC6 Doors & Locks 12 09-05-2006 11:23 AM
