Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 10-24-2009, 08:32 PM   #1
Profile:  Hollister , Missouri
Fuel Gauge Quit Working
I hage a 1996 Cutter with a 460. The fuel gauge quit working suddenly. Does anyone have a wiring diagram for the fuel gauge/sender unit. I'd like to troubleshoot before I drop the tank. Any help would be appreciated. Just need to know the color of the wires from gauge to sending unit.
PowerItUp is offline   Reply With Quote
Old 11-01-2009, 02:30 PM   #2
John Haggard's Avatar
Profile:  Jamestown , Kentucky
Check the Ground, On the sending unit 1st. If everything looks good at the gauge !
John Haggard is online now   Reply With Quote
Old 11-05-2009, 03:14 PM   #3
Thanks. It was the fuel sender. Finally figured out the wiring and in case anyone wants to know: 12v (Pink/Black), Ground (Black), Sender (Yellow/White) at the pump. Man what a chore it was replacing. Took about 4 hours total to drop the tank, remove old and install new. Just replaced it with an entire new unit including pump so hope I won't have to do it again anytime soon!
Emergency Trailer Brake Quit Working AustinAir Brakes & Brake Controllers 3 01-17-2009 09:23 AM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 07:08 AM
DC quit working in my new 64 Globetrotter GlobeTrottin Batteries, Univolts, Converters & Inverters 11 09-06-2007 09:06 PM
96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 10:05 PM
The ol' Dometic quit working... InsideOut Refrigerators 5 08-09-2004 06:07 PM
