Old 04-16-2014, 10:40 AM   #1
2006 39' Land Yacht 396 XL
Casselberry , Florida
Front side cabinet
Need to run a new CB antenna wire and connector on drivers side. Connector and wire has a short in it. Question is, how do you get into the side above the driver? I have been looking and can not see away? Help
Toftime is offline   Reply With Quote
Old 04-16-2014, 02:17 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
If you post a picture of the problem it makes it easier to discuss.
If yours is similar to the pictures below, can you not take off the lamp and just fish a wire forward to the Windshield Pillar and down from there?
OEM antenna was located directly above the window divider.
I doubt you have a short in the length of antenna cable, but more probable that it is shorted at either connector at the ends??? The ends connectors are replaceable, but you should check and adjust for SWR after connection to verify you have not alerted that.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 04-16-2014, 02:42 PM   #3
Pictures
This is the cabinet I am talking about. Outside mount is corroded. So I am replacing outside mount and all the cable. there is only a small hole if you remove lamp. not big enough to get to anything. Picture of side panel included.
Old 04-16-2014, 02:59 PM   #4
masseyfarm's Avatar
Images: 56
My panels on the CLIPPER have screws with the plastic caps, so are easy to remove.
Are you screws hidden in the fabric???? maybe access from below and also inside front cabinet??
When I enlarge your picture, I think I see two wood plugs along the top of the panel. Pull these out with a sharp pry, Knive etc, and the screws will be underneath???????
Sorry I can't be of more help on this project.
Dave
Old 04-16-2014, 05:20 PM   #5
Took two screws on top out, unscrewed light and slide out switch. Removed all sterio equipment out of front cabinet. Still can not get into that panel area. Anyone have any other ideas.
Old 04-17-2014, 10:38 AM   #6
masseyfarm's Avatar
Images: 56
I don't have a slide, but wonder if there is some access to the rear end of panel if the slide is extended????????????????
Dave
Old 04-17-2014, 02:57 PM   #7
No checked that also. Found the break/short, 3 feet up from plug. Cut the wire and put a new plug on end. No short now. Still can not figure out how to get inside cabinet without taking the front apart. Airstream really built these good.
Side to Side Leveling gorrissen Jacks, Stabilizers, Lifting and Leveling 26 08-02-2009 07:50 PM
Brake controller side by side comparison Boondocker Brakes & Brake Controllers 4 10-17-2007 12:05 PM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
Side-to-Side Flooring Replacement in Classic MH Eddy Repairing/Replacing Floor &/or Frame 12 11-03-2006 01:08 PM
Weight Distribution, side to side JimC Towing, Tow Vehicles & Hitches 8 08-13-2003 03:19 PM
