Old 07-17-2016, 02:28 PM   #1
1997 35' Cutter Bus Diesel Pusher
PEARBLOSSOM , California
Freightliner wiring diagram
Need the wiring diagram for a 1997 Airstream Cutter 35' diesel pusher. I have the diagrams from Airstream concerning their contribution, but there is no diagrams for the Freightliner XC chassis side, i.e., ignition switch etc.
jerryemeryde is offline   Reply With Quote
Old 07-17-2016, 10:58 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 53
You should be able to get any information you need on the chassis from your local Freightliner Dealer.
What specific is the problem?
Most problems with electrical are ground or poor connections. The wiring is only exposed at these locations. Poor fuse contact, or weak solenoids, can usually be diagnosed easily.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 07-18-2016, 11:57 PM   #3
I started out removing the tube tv enclosure from the dash and had to remove the dashboard to get all the screws out. During this process I decided to go ahead and fix the cracked Freightliner instrument cluster (done) and remove the obsolete Viper alarm system from the harness and replace the plastic faux claro walnut dash with real red oak. I removed the old tube backup monitor and restored the original ignition key switch to it's pre-viper condition, but I'm sure that the lights blinked with the alarm and there are splices in the original Freightliner harness. A schematic would same much time.Click image for larger version
Old 07-19-2016, 07:39 AM   #4
israndy's Avatar
2005 39' Skydeck
Alameda , California
I keep thinking I can fix anything that goes wrong in the RV, then I see how messy it can be underneath and it scares me.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
Old 07-19-2016, 11:28 PM   #5
Hang on, I'll be done in a couple more days and post a pic. The Red Oak dash is coming out nice and the Viper wiring is extricated. Cleaned out all the vent tubes and will probably install round a/c vents rather than the square stock ones.
1999 Freightliner Airstream Cutter Class A Motorhome eBay Watch Airstreams on eBay 0 10-31-2009 12:41 AM
1999 Freightliner Airstream Cutter Class A Motorhome eBay Watch Airstreams on eBay 0 10-23-2009 05:10 PM
1999 Freightliner Airstream Cutter Class A Motorhome eBay Watch Airstreams on eBay 0 10-16-2009 11:00 AM
Freightliner Chassis Torpedo Family General Motorhome Topics 0 05-19-2007 06:13 AM
