Old 06-25-2011, 08:52 PM   #1
95cutterbus's Avatar
1995 30' Cutter Bus LE
Peachtree City , Georgia
Ford fuse panel
My 1995 Cutter bus horn and fuel gauge are not working. I'm hoping it's a fuse. Here is a picture of the engine compartment fuse panel. Can anyone tell me which fuse powers what?
95cutterbus is offline   Reply With Quote
Old 06-26-2011, 04:48 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Should be a diagram inside the fuse box cover. Also might be another fuse panel under the dash. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 06-26-2011, 06:25 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Fords have a second fuse panel inside, usually near the driver's feet. That one should have a fuse for the instrument cluster, though it any of the gauges work, I doubt it's a fuse.
Old 06-26-2011, 03:44 PM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Fuse
Highly unlikely that the horn and fuel gauge would be on the same fuse.
Test the horn wire at the horn. Chances are it has poor contact. The fuel gauge may have the same problem. Check and clean all connectors.
Dave
Old 06-26-2011, 06:38 PM   #5
Thanks for the help. I'll let you know how it goes.
Airstream Central Control Panel DeltaBlues11 Electrical - Systems, Generators, Batteries & Solar 20 09-02-2014 04:24 PM
Fuse panel for the moho chassis? WineStream General Motorhome Topics 7 06-01-2011 10:02 AM
50 AMP fuse on Neg or Positive Pinchy Batteries, Univolts, Converters & Inverters 16 05-29-2011 07:56 AM
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 08:21 PM
2 roof panel questions jsapp Roof 2 03-24-2011 11:45 AM
