Old 02-27-2013, 06:05 PM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
flat front access panel - duh!
ok, so i figured out how to open the panel to gain access to the gen. but now, i can't figure out how to close/secure it.
or at least, i don't know how the bottom latches. any help is certainly appreciated!
JourneytoRet is offline   Reply With Quote
Old 03-04-2013, 04:53 AM   #2
well, finally figured out this conundrum - the bottom tab on the front panel was bent at a 90 degree angle. how this happened from when i opened it up is beyond me! bent it back straight and voila!, the tab goes into the hole and the latch holds it in place like it was designed. weird man!
Old 03-04-2013, 04:59 AM   #3
hissilver's Avatar
2018 25' International
Van Wert , Ohio
Airstreams often work in "Mysterious Ways"
hissilver is offline   Reply With Quote
Old 03-04-2013, 05:08 AM   #4
oh my, you can say that again. while i was rewiring my front mirror running lights, the front side marker lights would go ON, then OFF, then ON...
and the kicker is, the wiring, fuse box, terminals, etc. look very nice. but i think i will work on eliminating the 90,000 wire nuts from the PO.
