Old 03-21-2013, 10:08 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Exhaust Brake Stopped Working?
About a recently as a week ago, when I turned the Exhaust Brake switch on the dash, whenever I let off the gas I could feel the MH slow down dramatically. Now, when I drive the MH and let off the gas (diesel?) I don't feel any slowdown. What should I, or the mechanic check?
JourneytoRet is offline   Reply With Quote
Old 03-21-2013, 10:24 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
You should have a toggle switch on the dash. Have you got power to that?
The exhaust break on the exhaust manifold requires lubrication on the pivot points. See your owners manual.
The exhaust break can get a carbon buildup and stick if not used much, or used continuously at lower engine temperatures. This is hard to fix without removing it. Like anything else, it is designed to operate at engine working temp. that generally will keep carbon buildup under control. If you can get it working just try to cycle it to help free it up.
ps You have to be on the road for it to work as it is contolled through the Allison. I have not had the problem as I am in mountain country and my exhaust brake gets plenty of use.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-21-2013, 10:27 AM   #3
i'll check voltage to the dash switch. sure seems like the electrical system is tricky on these!
Old 03-21-2013, 10:58 AM   #4
masseyfarm's Avatar
Images: 56
PacBrake Lube
This may be newer than yours but the lube instructions should be the same.
The system works with electric over air.
Dave
Maintenance
Old 03-21-2013, 11:23 PM   #5
masseyfarm's Avatar
Images: 56
This document might be of help.
http://www.pacbrake.com/PDF/L5056.PDF
If you go to this site and select your application in the left column, you will find everything you ever wanted to know about Pacbrake systems.
Cat c7 engine brake, Jake Brakes, exhaust systems - Installation procedures and Schematics
Dave
Old 04-02-2013, 03:43 PM   #6
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
You can manually operate the valve by disconnecting the plug and socket in the 12V supply to the solenoid valve mounted down near the chassis rail. Can then run temporary 12V = & - from the starter battery to operate the air solenoid valve
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
Old 04-03-2013, 03:03 PM   #7
thanks tony for the tip!
