Old 08-05-2016, 01:29 PM   #1
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Emergency Exit
I finally got the SkyDeck back and cleaned it.
Checking out the Emergency Exit I pulled the handle down and it looks like the cable which is attach to it ripped off.
Now I have a none functional Emergency Exit what is not good but also have no idea how I can open it up to reattach the cable yo the handle.
Anybody has an idea?
Peter
PSchw is offline   Reply With Quote
Old 08-07-2016, 11:55 AM   #2
israndy's Avatar
2005 39' Skydeck
Alameda , California
Peter
Take the window out of the frame? Just peal the black rubber cover off the screws around the outside and have someone outside catch the window when you push it out. I don't actually know how to do the wire, I am just assuming it's the only way.
Congrats on getting your home back. How long did it take? What all did they do to it. Probably should post the answers in the thread about your roof repair.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: March 2018 Tesla Model ☰, a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles
israndy is offline   Reply With Quote
Old 11-12-2016, 10:59 AM   #3
israndy's Avatar
2005 39' Skydeck
Did that work?
-Randy
Old 11-12-2016, 12:22 PM   #4
PSchw's Avatar
Livingston , Texas
Did. It get yo it yet. Still trying to clean up after the work done on the roof.
Peter
Old 11-12-2016, 12:45 PM   #5
israndy's Avatar
2005 39' Skydeck
I am not sure if you and I have the same issue, my red handle window will not latch. Just a little push and the thing swings out on the top hinge. Has not popped while driving, nor let water in, but if someone wants into the RV just climb up on your car and pop in the window.
I would love it if I could figure out a way to prop it open all the time, let the air in and keep the rain out. Not enough ventilation in the RV when stored... Need to figure out a way to get some circulation going.
-Randy
Old 11-14-2016, 02:21 PM   #6
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Needs a hell of a slam to get it latched once you open it. Close your eyes, grit your teeth and SLAM it.
BUT if you don't open it once in a while you will find the rubber seals will be stuck so tight you will not be able to open it at all which isn't good in the middle of the night, gasping from smoke and really desperate to get out.
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
Emergency exit window reddogfox 2008 Safari SE 10 07-18-2016 04:33 PM
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
Emergency exit in case of fire? 3campers On The Road... 33 06-09-2013 11:05 PM
"Exit Now" or "Next Exit" which is better hhendrix On The Road... 2 05-23-2010 03:07 PM
Emergency Exit Window Operation gloran Windows & Screens 10 03-05-2010 02:39 PM
