Old 08-07-2011, 11:29 AM   #1
1999 35' Cutter Diesel Bus w/slide
Rimouski , Quebec
Electric shematic Cutter 99
I search for the shematic electrical for my freightliner chassis,i suspect a bad ground
landmarc is offline   Reply With Quote
Old 08-07-2011, 01:08 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
What specific problem do you have? The major grounds are located near the battery box on the frame.
On the links to Airstream manual I gave you in previous posts, you will find the schematics for the Airstream build.
This is specific to your 99 Cutter.
http://service.airstream.com/files/l...8c24bec252.pdf
If its a Freightliner Chassis problem, you may contact your local dealer for access to the manual, of ask if they can download a copy of the specific page,problem and email it to you, if you are not close to the dealer.
Dave
Old 08-07-2011, 07:45 PM   #3
Rimouski , Quebec
I contact Freigthliner and it can take 3 or 4 weeks to have an answer,my problems, is an intermittent warning when a release my parking brake ,i like to understand how it.,s work
I appreciate your cooperation
Marc
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-01-2011 09:40 AM
Electric Brake Question Gastrolith Brakes & Brake Controllers 4 06-21-2011 08:11 PM
WarmWire electric heat? j Z Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-11-2011 10:36 AM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
