Old 03-26-2014, 09:22 AM   #1
2006 39' Land Yacht 396 XL
Casselberry , Florida
Electric Plugs
I do not know if anyone has had this problem. When Dry camping running the generator, the plug for the washer/dryer and the 2 plugs in the bedroom do not have power. Everything else has power. But when I am plugged into shore power everything works great. I am at a lost on this. Any help would be appreciated.
Toftime is offline   Reply With Quote
Old 03-26-2014, 07:42 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Not sure what to say. My genset operates all outlets when running. However, if I am running the 2000 Watt Heart Inverter just on battery/Solar I loose two of the plugs on the passenger side of Clipper along with those two within the bedroom night desks.
Maybe Don can confirm how his works. His unit is close to yours in s/n and should be the same?????
My Heart Inverter, and also my PTS genset, have two reset fuse positions. Try resetting yours??????
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-27-2014, 03:48 AM   #3
Plugs
I have checked all breakers, fuses ect. Next thing is ti pull panels and check all wiring with meter. I am thinking I am losing a leg somewhere but with everything working when on shore power not sure. One of those mysteries.
Old 04-21-2014, 02:52 PM   #4
Got my issue fixed today. It was a bad relay in the transfer switch box not allowing 1 leg of the 120 into the box.
How Can it Be? 2 Plugs work, 2 Plugs dont Aluminumb Electrical - Systems, Generators, Batteries & Solar 10 07-27-2009 07:44 PM
Tidee Products Plugs in aisle? Chaplain Kent General Motorhome Topics 5 04-19-2005 07:50 AM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
Window drain plugs AccessMaster Airstream Motorhome Forums 10 06-20-2003 11:37 PM
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 09:04 PM
