Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes
Old 09-08-2015, 12:24 PM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
driver air conditioner AC fan speed
Here's a puzzler. While working on a turn signal problem, I was running the engine and air conditioner (to get a break from the southern heat!). While I was sitting in the driver's seat enjoying a splash of cold air, the fan stopped running at setting 4. I thought I blew a fuse. But when I turned the a/c fan speed knob, speeds 1, 2 & 3 worked fine, but speed 4 didn't do anything. Anyone have some ideas on what to check?
JourneytoRet is offline   Reply With Quote
Old 09-08-2015, 12:31 PM   #2
1974 Argosy 20
Kooskia , Idaho
There often is a relay for the highest fan speed which takes full alternator voltage to drive the fan at highest speed. You may have had a relay failure, or the wiring to it. However, the specifics of you individual rig are unknown to me. Just a general area to look into.
Old 09-08-2015, 02:36 PM   #3
Interesting, but I guess I never thought about how a 4-position switch actually provides 4 different fan speeds. Anyone have any idea where such a relay may hide? I guess I'll look in the fuse box to see if it's fused as well.
Old 09-08-2015, 03:21 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
What chassis do you have?
Most fan systems use resistors across the fan switch do give different voltages to the fan motor. #4 is usually a straight 12 volt feed and not the one that fails.
Look at the fan motor housing under the dash. If there are 4 wires going to it the resistors may be inside the housing. If only a single wire than the attenuation is done at the switch.
2004 Excursion 4x4
Old 09-08-2015, 03:59 PM   #5
richinny's Avatar
2011 34' Classic
at one time GM used a separate fuse for the highest speed on the blower. it was located in an inline fuse holder behind the alternator. i have no idea if your rig uses this system.
Ricky
Old 09-08-2015, 05:57 PM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Check the blower resistor. It is usually mounted on the air box in the engine compartment. It should have at least 5 wires on the plug. All vehicles have one, they just look a bit different. On occasion they are easy to get to.....
NavyCorpsman is offline   Reply With Quote
Old 09-09-2015, 10:55 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Ditto on the blower motor resistor-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-09-2015, 01:13 PM   #8
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
On the 96 CLIPPER, the fuse for the high speed is located on the front bulkhead, access from the front outside. The is after the relay that provides a #10 wire direct from the Chassis feed to the blower.
The resistor assembly for the three lower speeds is located higher on the front bulkhead, access from the outside, direct behind the dash area and fused separately.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 09-10-2015, 02:34 PM   #9
How Dave knows all this stuff about the Clipper is beyond me. I vote Masseyfarm to have 10 rivets.
Old 09-10-2015, 08:47 PM   #10
garypk's Avatar
1998 31' Land Yacht
lafayette , Colorado
If you have the 3 lower speeds that means the resistors are fine. There is a separate wire from the battery to the switch to bypass the resistor & give batt voltage for full speed. Ck the wire & inline fuse.
We call ours "Ship Of Fools"
garypk is offline   Reply With Quote
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? pejokerst Airstream Classifieds 0 02-19-2014 08:45 AM
Air Conditioner fan speed question? bmark Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-12-2012 02:24 PM
Low A/C fan speed still too fast gotohatteras Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-09-2007 12:37 PM
Carrier AC - Fan Speed adonh Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-04-2007 07:19 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
