Old 09-23-2015, 08:43 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
driver air conditioner
Has anyone tried recharging their system with one of those car care do-it-yourself kits? Comments?
300HP Cat Diesel
JourneytoRet is offline   Reply With Quote
Old 09-24-2015, 10:17 PM   #2
israndy's Avatar
2005 39' Skydeck
Alameda , California
If you have a leak that will be a good way to tide yourself over. If you it continues to leak get the kind that has a stain and it will show you where the leak is under UV light.
If you have air in the system that can cause it to not be entirely efficient. The fix for that is to have someone drain your system and then refill it. This causes moisture to evaporate and be purged with any air. Then they ONLY put back coolant. This will make sure your system if perfect, assuming there is no leak.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
Also a 1999 Jeep Grand Cherokee, 2000 Honda Hybrid Insight, new 2013 Volvo C70 hardtop convertible
And all electric: a 2012 Mitsubishi i-Miev and two 2007 Vectrix VX1 motorcycles, waiting in line for the Model ☰
israndy is offline   Reply With Quote
driver air conditioner AC fan speed JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 09-10-2015 08:47 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Air conditioner compressor rdm Mechanics Corner - Engines, Transmission & More... 2 05-13-2002 06:54 AM
