Old 03-04-2014, 08:17 AM   #1
2006 39' Land Yacht 396 XL
Casselberry , Florida
Door Awning
Yesterday the Awning over the door came apart. the springs in the tube shaft busted. Has anyone replaced there manual awning with one of the newer man or electric ones from A&E that come straight out?
Toftime is offline   Reply With Quote
Old 03-04-2014, 08:53 AM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Is this the one you are talking about.
I never liked it, the metal hardware was rusty no matter what you did and it looked bad. I replaced it with the Dometic Oasis power door awning. Products - Dometic. It operates from a a switch mounted by the door and it also works with my remote for the main side awning. It looks much better and works great.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-04-2014, 09:06 AM   #3
Door awning
That is the one I am talking about. Thought I would replace it with an electric one. How much trouble was it to do. Where did you get power from or run wires to?
Old 03-04-2014, 09:16 AM   #4
adonh's Avatar
1976 31' Sovereign
I had my local RV shop replace it. The biggest issue seemed to be running the wiring to the Dometic power control located in the storage bay by the door. I had recently had the original side awning replaced including the power control box for the Dometic weather pro awning. The door awning connected right to this box with no issues and the remote was programed to work as well.
One other issue is where the old manual awning connects to the side of the coach down the side of the door. This awning was installed before the coach was painted. So when it is removed you will have 3 sets of rivet holes and white spots on each side of the door to deal with.
Don Hardman
1976 31' Sovereign
Old 03-04-2014, 03:12 PM   #5
Door awning.
I have been looking at that. Running the wires is going to be the hardest. And I saw that the fittings were put on before paint.
Old 03-04-2014, 04:33 PM   #6
adonh's Avatar
1976 31' Sovereign
They put rivets in the holes that held the fitting to the coach but that looked bad. Filling the holes and repainting is a big project. So what I did was cover the top holes with 2 small American flag emblems something like this one.
American Flag Car Auto Truck Grille Badge Emblem New | eBay
The ones I found may be a little smaller.
The bottom 2 holes I covered with small vent emblems something like this.
http://www.sfxperformance.com/parts/PAR61-0208.htm
Mine are round. All of these stick on with 3m double side tape and cover the holes and unpainted area. I don't have any actual pictures with me, but they look good and don't look out of place. I have been at Airstream rallies and have shown others that have this coach the new door awning and they didn't even notice them until I pointed them out.
Don Hardman
1976 31' Sovereign
Old 02-14-2016, 07:12 PM   #7
israndy's Avatar
2005 39' Skydeck
Alameda , California
So did you replace the awning or repair it. Seems like it would be much cheaper to repair and then you have a use for all those rivet holes. Mine just came apart and I will need to decide myself. I am curious about repair. Must have been designed to be repaired, but I cannot even find documentation on getting it down.
-Randy
2007 LTV Serenity beater 2005 Airstream SkyDeck
israndy is offline   Reply With Quote
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
