01-29-2011, 06:18 PM
TorpedoFamily
2014 30' Classic
Ozark
, Alabama
Docking Lights not working 396 XL
I have checked the fuse, works, switch says they are turned on, NO lights. All six are not working?
Any help will be appreciated.
Torpedo Family
Ozark, Alabama
01-29-2011, 08:02 PM
1989 34.5' Airstream 345
Jamestown
, Kentucky
start at the fuse and see if it is Hot. the fuse can be good but may not be fired up.
If it is then trace the wire to one of the closest lights
01-30-2011, 08:52 AM
Streamin'
1995 30' Cutter Bus LE
Madison
, New Mexico
Yep, start checking from the fuse on out. Is everything else working normally?
I'll have a look at my wiring diagrams to see if any thing is special about the dock light circuit.
01-30-2011, 10:01 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
Dock Lamps
Are you working on 2001 36' Land Yacht XC or have you got another that is not listed in your info?
All OEM information is available for the units later that 1998 on-line.
Did they work recently? You should have left and right switches? so they should work independent. You need to check for power at the switch first.
Could be a bad relay, but need the year and model to find location on spec. sheets.
The sealed beam lamps (H9411 GE HALOGEN TRUCK SEALED BEAM LAMP)
are rather expensive. They were used on the 90's Chev pickups.
Dave
01-30-2011, 05:55 PM
TorpedoFamily
2014 30' Classic
Ozark
, Alabama
I have a 2005 396 XC with the docking light problem. I just purchased this one last month. Have a few other problems with this neglected coach. It sat up for at least 3 years. Thanks for the help
01-30-2011, 08:43 PM
Tub City
, British Columbia
396
[QUOTE=Torpedo Family;944568]I have checked the fuse, works, switch says they are turned on, NO lights. All six are not working?
Torpedo Family
Ozark, Alabama[/QUOTE]
Is this yours???????
01-30-2011, 09:32 PM
Tub City
, British Columbia
396XL Owners Manual 2005
If the above unit is yours you will find the manual with all wiring scematics here.
http://service.airstream.com/files/l...17f820f8c6.pdf
Dave
01-31-2011, 06:41 AM
Jamestown
, Kentucky
Originally Posted by masseyfarm
Hmmm, I like that unit, wish it were mine to fix
01-31-2011, 04:33 PM
Tub City
, British Columbia
Dock Lights
Mine has two switches for left and right. On the drivers side the circuit also includes the rear flood lamps, that also activate with reverse gear. Try putting it in reverse to see if these lamps work, and then turn left switch on. If its a ground, this may be enough to activate the relay??
Let us know what you find.
Dave
02-02-2011, 03:48 PM
2000 35' Land Yacht XL w/slide
Vermilion
, Ohio
All,
My Furnace fuse blew, I looked at the fuse panel- it was clearly marked furnace,
Fuse was fine, -- After hours of tracing wires, it hit me " What if the panel was labled wrong? ----that easy, the fuse for the bathroom fan was really for the furnace
So my advise go back to the fuse panel and check all fuses.
Good luck
Rob
02-02-2011, 04:14 PM
Jamestown
, Kentucky
Originally Posted by myfirstrv
All,
Good luck
Rob
Vermilion ? we spend a Month or two west on rt. 6
at the Beulah Beach camp site down by the lake.
Love Vermilion area
02-03-2011, 11:49 AM
Vermilion
, Ohio
I bought my RV from a family that lived in the condos just West of there and south of route 6. Small world - I have a cottage about 4 miles west of Beulah Beach
02-03-2011, 12:06 PM
2000 31' Land Yacht
Central
If fuses and switch are good, I would look for ground, my LY has a ground near the front right docking light. Bad thing about schematics is that they don't locate actual wire point. If it was sitting for 3 years check for rodent chewed wires.
You say the switch is turned on but did you test for 12v at it's contacts? My driving lights have to be on to get the auxillary headlights to work.
02-04-2011, 02:10 AM
Jamestown
, Kentucky
sure is, My wife, from Orrville has been going up for youth camp since 1955 or so. our children attended and worked there for many summer s when they were old enough.
Now we all go back for family reunions with our four children and 9 grandchildren.
we do like the homes to the west and I know about where you are. We have friends from the Marion area where you are also.
we may try to attend the rally at the Wayne co fairgrounds in April also. the 8th. or so. like being home again.
