03-04-2013, 04:40 AM
2000 36' Land Yacht XC Diesel
Gaffney
, South Carolina
Dock Light Replacement
Has anyone a source for the exterior dock lights? Looked around the forums but couldn't find anything. I attached a pic of what I have (at 4am today!).
The back of the sealed light has some odd straight wire pins.
03-04-2013, 10:19 AM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
I don't have the number in memory, but these lamps are stocked at any auto parts store. IIRC the part number is on the back of the lamp.
Here is the info. The lamp number is H94060
Docking Light
- Multi-purpose
- Flush mounted
12 Volt applications
Part Number
Description
Lens
Color
Replacement
Bulb#
07803Lamp with stainless steel Bezel, wiring and screws for mountingClearH94060
7812Lamp with Black Powder coated bezel, wiring and srews for mountingClearH9406
Part NumberDescriptionOEM Part Number"A" Dimension"B" Dimension"C" DimensionQty09040-4Standard, Zinc Plated SteelNA5.0"3.38"1.3"Pair
09050-4Freightliner "A", Zinc Plated Steel18-029394.25"2.625"1.3"Pair
09090-4Freightliner, Zinc Plated Steel22-11628-0003.25"1.75".86"Pair
09110-4Standard, Zinc Plated SteelNA4.75"3.65".187"Pair
09130-4Bracket, Black E-Coated SteelNA3.30"2.20"1.80"Pair
09140-4Bracket, Black E-Coated Steel68154433382.71"2.22"1.8"Pair
09150-4Bracket, Black E-Coated Steel06-18166-0002.875"2.25"1"Pair
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
03-04-2013, 12:12 PM
Tub City
, British Columbia
Airstream Dock Lamps
03-04-2013, 02:01 PM
Gaffney
, South Carolina
Perfect Dave, found them on amazon for about $40/ea.
04-02-2013, 03:04 PM
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah
, NSW Australia
Cheaper at NAPA but that is just for the replacement "bulb", not including bezel.
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
04-03-2013, 11:28 AM
2001 30' Classic S/O
2001 36' Land Yacht XC Diesel 300 hp w/slide
Helotes
When I replaced mine I went to Walmart and bought the high beam from a 1970's Chevrolet pickup with 4 headlights Worked fine
04-03-2013, 03:02 PM
Gaffney
, South Carolina
smart Ismith!
05-26-2013, 07:55 PM
2005 30' Land Yacht 30 SL
Castro Valley
I just found the packing list: I bought two H9406 bulbs on the web 4 years ago: H9406 were 16.39, now the same vendor wants 24.95. A local rv place that repaired the right front corner after an encounter with a Mustang (a different long story) charged me $40 for the bulb! I wonder why they have not seen me since then? Maybe excessive markup? My local auto parts store shows about $22 today.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
09-08-2013, 10:56 AM
Rocket Man Ken
2001 39' Land Yacht XL 330 hp w/slide
Brookville
, Ohio
Pretty sure these are simply automotive sealed beam lamps.
'Of course that's just my opinion, I could be wrong'.
09-08-2013, 05:39 PM
Tub City
, British Columbia
The dock lamps used on the Airstream Motorhomes are the 9400 series.
http://www.airforums.com/forums/f313...ml#post1300531
The similar style lamps used as auto headlamps are 4700 series (H4703 etc) and, although similar, will not fit the bezel of the Airstream Dock Lamps.
The bezel can be trimmed if the proper lamp is not available. You would have to trim about 1/4" off each side of bezel for the lamp to fit, and it would still look wrong as it would not fit in the corners properly.
If you have another part number, that you are thinking of that works, let us know.
Dave
