Old 02-27-2013, 10:13 AM   #1
JourneytoRet's Avatar
2000 36' Land Yacht XC Diesel
Gaffney , South Carolina
Diesel Gen Starting/Stopping (newbie)
Is there a preferable way to start or stop the diesel generator?
Also, while driving down the road, would I need the gen to run in order to run coach heat or a/c?
I've searched the threads but don't see anything for this, so it might be a basic question. And, I didn't find a manual for it in my pack of manuals.
JourneytoRet is offline   Reply With Quote
Old 02-27-2013, 10:23 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Your unit should be Onan.
I can't help you there as our previous units were PTS.
http://www.airforums.com/forums/f313...ml#post1177725
Someone with the newer units will answer you.
Dave
Old 04-02-2013, 06:38 AM   #3
Rocket Man Ken
RocketManKen's Avatar
2001 39' Land Yacht XL 330 hp w/slide
Brookville , Ohio
Running furnace should not need gen running as it is 12V. Rooftop A/C will run on inverter for short time. Typically you would run gen if you need coach a/c. Dash a/c is just like your car.
'Of course that's just my opinion, I could be wrong'.
RocketManKen is offline   Reply With Quote
Old 04-02-2013, 08:13 AM   #4
1974 Argosy 20
Kooskia , Idaho
A diesel, like all generators, should be started with no load on it, run for about 30 seconds or so, load applied and you are good to go. Stoping should be the reverse, remove the load, let it run 30 seconds or so, shut it down.
