Old 06-04-2014, 10:17 PM   #1
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Cutter Stairway Cover
Next thing will be installing a gas strut on the cover that hinges down over the front entry stairs - to save the admittedly minor hassle of messing around with the press stud. It will not need to be secured in the up position and should go down in a slightly more controlled speed than the current free-fall mode.
Before I get too technical with weights and moment arms and such, I thought I would check if anyone has beaten me to it and figured out optimum length and force for the gas spring
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
Tony Lee is offline   Reply With Quote
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 09-07-2011 01:40 PM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-22-2011 06:30 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-11-2011 10:10 AM
1999 AirStream Cutter 35 Diesel pusher Huge slide out S1999 AirStream Cutter 35 Diese eBay Watch Airstreams on eBay 0 08-01-2011 09:40 AM
'98 Cutter Roof Vent Cover Pam Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 01-29-2007 02:27 PM
