Old 03-24-2012, 05:31 PM   #1
1998 30' Cutter Bus (Chevy)
Sarasota , Florida
Cutter info
Hello Cutter Owners; I have written before regarding real wheel trim.
I have been successful in ordering wheel well trim and other parts.
First call or email Airstream and obtain part numbers, if calling when you finally
talk to parts they are super about helping, by emailing parts catalog pages
with part numbers. Armed with part numbers, call a dealer, I called Manteca
Trailer in Manteca Ca. parts man named Harry was super helpful. My ordered
parts will be dropped shipped to my house.
My 1998 backup camera went South, I installed a new Voyager wireless system in
about two hours. The monitor has a cigar lighter plug, I cut off the plug
and connected it to the original camera wiring. The camera requires 12 volts to operate, I tried to outwit the instructions by using the original wiring, that didn't
work, all I accomplished was covering myself and the rear of the RV with fresh sealant, eventually I gave in and connected the camera to an adjacent clearance light. normally in a 12 volt system red wire is 12V and black is
ground, on my clearance light black is hot and white is ground. The clearance lights have to on to use the camera, I consider it the lesser of two evils
by not running a 12V wire from the front of the RV.
Now for a question does anyone have a source for the hydralic park brake system?
We have decided to stay one more year here in Redding then travel full
again, I should be able to repair the squawks by then.
Hope this helps someone. Regards Jim
jcessna is offline   Reply With Quote
Old 03-26-2012, 04:36 PM   #2
1998 35' Cutter Diesel Bus w/slide
Laud by the sea , Florida
my bus's camera wont tilt, any suggestions?
its the original on the rig..
Thanks!
mfancher is offline   Reply With Quote
Old 03-26-2012, 05:05 PM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
They are just a small solenoid switch at the camera. Access it by taking the panel over the camera off and take the switch off and spray it with silicone lube. Hook it up to power and continue to work it until it is free. They stick from non use. If you think its broke now, what harm can you do to it???
Dave
Thanks!
1965 Streamline Duke - INFO REQUESTED LarryGlover Vintage Kin 14 06-20-2012 08:56 AM
Cutter info jcessna Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 03-26-2012 05:05 PM
Who carries new wiper blades for 35 cutter? mfancher Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 03-26-2012 02:32 PM
I need some parts for my '98 35' Cutter! mfancher Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 03-21-2012 06:12 PM
A little info please before buying a Classic... Corrales Kid Classic Motorhomes 6 03-18-2012 06:55 PM
